Mike65
Unloaded a couple sheets of maple plywood for a mobile tool cabinet I am going to build for my woodworking shop.
Cleaning up then some bronco time. Sore as hell today so probably see if I squeak out some time om the couch with NASCAR.
sweet box, not my color, but sweet box.
I did the broken chain repair on our tiller a few years ago.
I bought a new one for the drive axle, endless. In hindsight I probably should have replaced the one for the tines while in there.I did the broken chain repair on our tiller a few years ago.
I used a master link to repair the broken link and put it all back together thinking I was so smart. Well it lasted about 20 minutes and broke in another location. I then installed a brand new continuous chain.
Apparently these chains experience such shock from use, that all of the links pretty much wear out at the same time.
In full transparency, it’s the Hobo freight box with Snap on emblems added. Have a buddy that’s a snap on freak, so I was razzing him.sweet box, not my color, but sweet box.
Back when I bought my used SnapOn box, the HF ones were pretty much garbage. Today, I would own one in a heartbeat.In full transparency, it’s the Hobo freight box with Snap on emblems added. Have a buddy that’s a snap on freak, so I was razzing him.
It's been going around.oof.. wrong thread...
As I recall you mounted the light on the ROPS - from the shot I saw it looks like it would be right over your head.Installed the delay timer on the lights on the zero turn. This little device is crazy powerful for what it is. It has the ability to accept two different triggers or simply start when power is applied. All I'm using it for is to delay turning on the lights on the zero turn for 5 seconds after the switch is put into the AUX position. I went with this device because I have other ideas for what I want to do with one and this is a simple test case.
I did and we do. I'll give this a go. If it becomes an issue, I can move the light to the front of the zero turn.As I recall you mounted the light on the ROPS - from the shot I saw it looks like it would be right over your head.
I hope you don't have a lot of bugs out at night.......
I wouldn't worry about it.There is no place on the machine to mount the lights that is really far from your face and simultaneously lights up your work area well.I did and we do. I'll give this a go. If it becomes an issue, I can move the light to the front of the zero turn.
Rainy day lazy just hanging in the garage when for no reason at all I started to clean up the old Craftsman Crown box that used to be my FIL's.
The amount of dirt, grime, oil could only be compared to an old yellowed out coating of shellac. After about an hour of cleaning I managed to get the drawers and top front of the box to a state of nice patina.
I have no desire to, nor will I actually restore/repaint the box, but at some point I'll clean the remaining three sides. Another rainy day lazy time down the road.![]()
The timer itself is still only $15. The controller is another $17 or so.I've used those from Timers.shop before - agreed it's amazing what you can do with one and they were relatively cheap, like $20 (but that was 10 years ago).
I setup cornering lights for turn signals on a vehicle that I did an engine swap on and the new engine controls didn't have that functionality but I wanted to keep the corner lights. You need corner lights to be on, only with the respective turn signal, not hazards, only when the headlights are on and they need to be on steady, not flashing.
I painted my workbench. I got tired of sanding on it and needed a morale boost.
That's a trx70 with a Chinese 125cc manual clutch motor. It's sitting on my wheelchair lift that I bought when I crushed both my heels. I'm going to use it in the shop if I can or I'll just sell it..What is that Honda up on that shelf/rack/lift? If that is not a lift, how did you get it up there?
