Shiftless
Of course!!!Down the drain--it's sold as drain cleaner, after all
If my neighbors are pouring acid down the drain my lye will neutralize it before it gets to the sewage treatment plant.
and there are different brass alloys@jawstight : You might be able to use the old jaws to "impress" the pattern onto the new brass jaws--but without heat, you get one try. Brass work-hardens easily and HARD.
Brass is pretty hard but not as hard as Bronze. You might have been better off using Copper. Soft Copper would form easier when pressed into serrated jaws.Finished the brass soft jaws for the 9300. Didn't spend a lot of time shining them because this will be a working vise. Didn't bore a hole for the pin either. Happy with the way they turned out though. This workbench I often use for work on firearms, and that is the plan for this vise so these jaws should come in handy.
Question for you all though, since I'm not a machinist. If I press the faces of these brass jaws face to face against the faces of the checkered jaws, in a larger vise, will I be able to get any sort of checkering applied to the brass jaws' faces? I don't want to deform them much (actually not at all), and they don't need the deep checkering of the steel jaws, but a little unevenness in the surface of the faces would help them to grip better. I generally don't need or want to apply a whole lot of clamping force on firearm components. Caveat, I don't want to use heat.
I should have included this: "C360 Brass flat bar, H02and there are different brass alloys
Super clean! It’ll look even better nickel plated!! [searches on GJ for other examples]Fulton 5190 vise. 3" wide smooth jaws and opens about 3". Cleaned up and will nickel plate this summer. Its for my Fulton collection of various tools. Was looking for a small vice with smooth jaws and a nice horn. This one fits the bill.
Okay, slight diversion, I had to update my work bench. I have a small work area, so I don't have a fixed bench at the moment, so I upgraded my work stand. Been put to work several times already. It's a great addition to the shop.Located around the block. Seller not listing much info other than $50 take it or leave it. What do you make of this, I'm thinking for all purpose vise it might work? Can any of your aficionados tell much the pic?
Nice. So you put a thick top and beefy vise on a WorkMate equivalent. I’m just getting caught up on your other recent posts. I like it.Okay, slight diversion, I had to update my work bench. I have a small work area, so I don't have a fixed bench at the moment, so I upgraded my work stand. Been put to work several times already. It's a great addition to the shop.
Awesome job on your restore. What color red is that? I just bought Rustoleum Sunrise Red for my next restore.Hey all,
Well I got it all done, thanks to you all. Without you guys I would probably would have wound up with a vise from Horrible freight.
$50 on Facebook Market place
$30 1-7/16 1/2" drive socket
$10 cupped wire wheel
$10 spray lube
$17 Evaporust
$16 Rustolium
Result = vise that works smooth as heck. It's a beautiful thing. I know sometimes I might ask basic questions that seem annoying to some but I always learn something valuable from you guys. I forget who (beerhippy?) recommended it but I bought the spray lube. That is the real deal - I never heard of an oil like this.
Thank you all - I've got a real vise now even better than the old one I lost in my travels and it's ready to go to work!
RP
Ahh, Always learning. I'll curse myself first time that comes up, but thank you.Nice. So you put a thick top and beefy vise on a WorkMate equivalent. I’m just getting caught up on your other recent posts. I like it.
Ideally, that vise would be closer to the edge so you can hold things vertically in your vise that extend past the table top.
Yes, Rustoleum red!Awesome job on your restore. What color red is that? I just bought Rustoleum Sunrise Red for my next restore.
Before having anything custom made, I would get a narrow strip of 24 ga. Aluminum flashing and cut it to match the circumference of the screw. Make your own bushing, That might be good enough to take up the slack and eliminate the wobble. If it was too “shade tree mechanic” it would at least give you a close idea as to the thickness needed for your custom made bushing.Is there a bushing (sleeve or flanged) that would be thin enough to fit over the screw to take up slack? If there were.. what measurements should I look for?
Hmm.. maybe cut this out from an aluminum soda can?Before having anything custom made, I would get a narrow strip of 24 ga. Aluminum flashing and cut it to match the circumference of the screw. Make your own bushing, That might be good enough to take up the slack and eliminate the wobble. If it was too “shade tree mechanic” it would at least give you a close idea as to the thickness needed for your custom made bushing.
You might find a source for some thin wall tubing. Cut off a short piece and there is your bushing,
That should be pretty close to 24 ga. Maybe a bit thinner? 26 ga?Hmm.. maybe cut this out from an aluminum soda can?
Assuming that soda cans are the same as the cans we use at the brewery, the thickness is 0.005". Older cans--say twenty years ago, were 0.010".That should be pretty close to 24 ga. Maybe a bit thinner? 26 ga?
Go ahead and try that. For most of us, it’s easier to find an old soda or beer can than a piece of flashing.
The McMasters Carr part costs $35 plus shipping. That makes an empty aluminum can look pretty cost effective. (If it works at all)
Wilton used Bronze material on theirs. It holds up better where the handles slide. Kind of thin wall in that area. Looks good though. This set on my C1 are Bronze and original except I added the swivel handles.Here are 1/2-13 thread, brass swivel base handles that are designed to replicate the style Wilton used on the early 1940' fishhook style vises that I made. Let me know what you think!
that is awesome! Thanks for point that out, I thought it was brass. Did Wilton issue the washers under the handles from the factory?Wilton used Bronze material on theirs. It holds up better where the handles slide. Kind of thin wall in that area. Looks good though. This set on my C1 are Bronze and original except I added the swivel handles.
Might even be oil impregnated bronze.Wilton used Bronze material on theirs. It holds up better where the handles slide. Kind of thin wall in that area. Looks good though. This set on my C1 are Bronze and original except I added the swivel handles.
ID of a 3/4" copper sweat coupler would, indeed, be 7/8". OD of copper pipe is always nominal dia. + 1/8".Fishwatcher: A few suggestions; find a short piece of rigid copper tubing, maybe a female-female coupler.
A short piece of tubing can be slit lengthwise then opened up to have an ID of 7/8", slide it over the mainscrew.
A 3/4" coupler may already have an ID of close to 7/8".
Last idea: use more than one layer of beer can or soda can: wrap it around the mainscrew like tape. This will then
be much thicker and may be what you need.
If I get a chance and remember to look, I'll measure a 3/4" copper coupling for ID and OD.
PierceA
No I added the washer‘s. I use 1144 Cold Formed CRS for the handle material. It’s great stuff. Here is some drawings I created back when I was building vise parts. You might already have these drawings but if not add these to your collection. Good luck selling your lockdowns.that is awesome! Thanks for point that out, I thought it was brass. Did Wilton issue the washers under the handles from the factory?
Wow thank you! I’ve got several drawings, but you got a few here I haven’t gotten around to making up, thank you!No I added the washer‘s. I use 1144 Cold Formed CRS for the handle material. It’s great stuff. Here is some drawings I created back when I was building vise parts. You might already have these drawings but if not add these to your collection. Good luck selling your lockdowns.
Not so certain anymore, but back when I worked in a brewery, the different brands used different thicknesses of cans. The big boys all used the thinnest they could, as a million cans a day was expensive at any rate. Three mid tier used slightly thicker, the little guys used the thickest, cuz the older equipment could be reused / resold down the food chain.Assuming that soda cans are the same as the cans we use at the brewery, the thickness is 0.005". Older cans--say twenty years ago, were 0.010".
There's been a lot of changes since then. Seems most cans are the same--0.005". Aluminum got more expensive a while back. Not sure of the thickness of the cans the big guys use--I drink what we make.Not so certain anymore, but back when I worked in a brewery, the different brands used different thicknesses of cans. The big boys all used the thinnest they could, as a million cans a day was expensive at any rate. Three mid tier used slightly thicker, the little guys used the thickest, cuz the older equipment could be reused / resold down the food chain.
The big money savings is in the smaller lid diameter as well.
Nowadays with contract packaging, mobile packaging units, etc, I can’t be so certain based on market as I used to.
I’ll definitely try this. Your experience using cans as shim stock gives me additional confidence.PS: I've been using beer cans as shim stock for a few decades, which is why I keep track of the thickness.
The intersting thing is that i've had several requests for Brass handles, I guess people just made the assumptionWilton used Bronze material on theirs. It holds up better where the handles slide. Kind of thin wall in that area. Looks good though. This set on my C1 are Bronze and original except I added the swivel handles.
Most people don't know **** from Shinola when it comes to metals. Or much of anything else practical.The intersting thing is that i've had several requests for Brass handles, I guess people just made the assumption
