I have a portable shed that I am wiring a sub panel into. We will have lights, TV, AC, fridge, vent fan and a few receptacles for convivence. This shed will at times plugged in to an RV power pole (30 AMP). But because this property only has 100 amps total, I plug into a generator during events. Basically, I have wired this to be just like an RV. Where ground and neutral are the same at this box.
Talking with local electricians, most cannot understand the requirements of this situation. Some say I simply cannot do what I want to do and "be safe". There will not be an inspection.
I have not run the electrical from the main building yet. But that will be a 110VAC 30AMP breaker feeding an RV electrical with the 30 AMP RV receptacle, and a 15 amp receptacle. I just want to be sure I am not back feeding the main building something bad.
This is the panel I will be connecting to. https://www.homedepot.com/p/Connect...-with-Branch-Breakers-CESMPSC41GRHR/100669963
