Honestly I don’t think I have heard of someone making their own gaskets by cutting them. I guess all the cars I work on are new enough within 20 years that you can buy them.
i always thought “making a gasket“ meant using something like RTV
@Wamsutta or anyone else would you mind writing a few sentences on what gasket making is all about for us noobs?
Make ‘em all the time!
Obviously, for some things such as cylinder head gaskets, you need a specific part, but for anything that uses a paper gasket they’re easy to make.
To do it properly you need some gasket paper. It’s usually available in different thicknesses from a good motor factor, although I keep some on hand.
I use “Flexoid” but they are a British maker. Bound to be a U.S. one.
Just plonk whatever you need a gasket for on the gasket paper and draw round it with a sharp pencil. Alternatively, put a thin smear of marking blue on the component (or don’t bother if it’s grubby enough!) and just press it on.
I usually punch any holes next, using the appropriate size hole punch or wad punch.
You can get sets of these which include popular Imperial or Metric sizes.
Finally, just cut round with a good pair of small scissors. Job done.
If you prefer, and you’re careful, just cut round the component directly using a scalpel.
Some gaskets need to be made from thicker rubber or cork, but I’m up for having a go at those too. A “Major” scalpel is the ideal tool for cutting these.
A sheet of lead is a great base for cutting out on.
