Trailer stake pocket jack
free07110
Edmond ok
Bought a new trailer and looking for ideas to always have a foot jack incase I have a flat tire without added toolbox.
Wanting to fab a stake pocket tie down anchor and weld on a swivel jack adapter to the tie down anchor. This way I can have a swivel/removable jack to slide in any stake pocket and use as a floor jack incase I ever have flat tire. Easy storage too since it stays in a stake pocket and no need to get a toolbox to carry floor jack. Anyone ever fab such a thing for their trailer? If so, post your setup.
WoodsTruck
Can the stake pocket adapter with the jack point slide up into the stake pocket from the bottom?
I need to weld some round adapters on the back sides of my stake trailer for that purpose. I got an extra load and length jack for that purpose.
F
free07110
Edmond ok
It's dual axle, can't you just carry a chunk of 4x4?
Put it in front of the bon-flat tire, pull forward about 6-10" and now it's jacked.
I have done that in the past and worked great. Also used the ramp with 4x4 and backed up on the ramp with good tire to raise the other axle up that had the flat.
The thing is I lost my 4x4 while back and want something I can just grab the trailer and go without worrying about having everything.
PCustoms
VT
I guess I don't get how making sure you have the jack and adapter is better then making sure you have a 4x4 with you.
I would just make sure the pocket, adapter and jack are rated for the loaded trailer. A 2,000lb tongue jack is massively underrated for this application IMHO.
Garage Junkie
Cleveland, OH
Here is what I did. This was primarily to stabilize the end of the trailer when loading/unloading a 12k lb skidsteer. But between the two rear jacks and the tongue jack, I can lift the entire trailer off the the ground if I wanted to. And the two rear jacks are removable so they don't rust or get damaged.
mike93lx
Richmond, VA
Notch a 4x4 to slide in a stake pocket. Repeat when you lose it
Otherwise, I think I would weld mounts on each side like @Garage Junkie did and then use a standard pipe mount jack. Makes it easy to replace if it ever gets damaged and you really shouldn't need to be able to move the jack around beyond that
2Rocky
aka Larry
Eastern, NC
Looks like what i would have done in your situation.
This is what I have in each of the trailers on the ranch:
These work great. Super easy to use and would be my go-to solution over a jack.
mikegt4
sw ohio
Going back to the OP's stake pocket concept, one could make something that would slide into the stake pocket like the tie down adapter except come up from underneath with some ears to stop it from sliding all the way through. Could even have a pin to keep it from falling back out, think upside down tie down adapter. Weld the jack adapter socket on the part hanging below the stake pocket. Excuse my very crude drawing, hopefully it gets the concept across.
NUTTSGT
Northern Central Ohio
If I were to make a stake pocket jack mount I would probably do something out of steel tube, sized to fit in stake pocket. Length would be determined by height of jack. . . . all in theory. . . I don't have the trailer to measure it all out.
Drill 2 sets of holes parallel with enough distance the stake pocket could fit between. This allows it to be pinned in place. . . up or down with pins like this .
Weld the swivel jack on one side of the tube, where the jack can be pinned for travel, up out of the way. Pull ********, pull pins and flip the tube over, insert from the bottom of the stake pocket, re-pin tube in place and remount jack to tube.
Basically creates a 2 position jack mount, stow position and jacking position.
NUTTSGT
I'm glad you posted that. That gives me an idea for mounting a step at the rear of my dump trailer. Thanks.
jblnut
In the Middle of MN
I put a bottle jack and a few blocks in the toolbox of each trailer I own. If it doesn’t have a tongue toolbox I added one. Each trailer has its own set of straps, chains and binders and on two I even keep a drop hitch with a ball on them as I rent them out on occasion and I don’t have to worry about someone putting a 2-5/16” trailer on a 2” ball.
The stake pocket jack is a neat idea. I’ve never changed a non farm trailer tire on the side of the road before. When cracks appear they get pitched on the used pile and new ones get put on. The last thing I want is a blowout at 70 mph with a loaded trailer dragging me around. No thanks.
mikegt4
sw ohio
Ideally the “ear” would be on the inside edge and meet the trailer frame. Then you’re lifting on the frame, not the stake pocket.
True, but that would depend on how your trailer was built and may differ on which stack pocket you happen to be using at the time. One could weld a piece of angle iron across the back side to catch the bottom of the frame, depending on your trailer that may require lengthening the device considerably.
