sawduststeve
Chimney Sweep.Well you are showing your baby, so I won't comment about you showing your wood off.
Any plans for it yet?
Earn a couple of quid until they get too big.
Nice!
I've always loved watching your projects and your woodworking skills, but you probably could have done an entire thread on just the deck. WELL DONE SIR!!
I have a couple questions since i'm getting ready to resurface my old 32 x 16 deck with a couple long steps up to a smaller 8x10 ish deck. would you still use Timbertech (which type did you use) and how has it weathered the last year or so or is there another product you wish was available or that you knew about? did you use the screws and plugs or the hidden fasteners? aluminum railings?
I noticed you did the blocking to firm it up so did it? also are your joists 12 inch on center or 16?
Thanks and keep up the great work and have a great day!!
Is it in your shop yet?
If it wasn't for the moulder it probably would beIs it in your shop yet?
Are you sure there isn't an addition to your shop in your future??
What are you waiting for?I need a separate detached 60x120 to fit all my wants
Thanks for the 411 on your Timbertech deck. you did an excellent job and I'm not sure you mentioned what it ended up costing you in materials and labor not including yours, but I bet it was a bit less than the 90k bid you recieved.
would you do the aluminum railings again too if you had a choice especially with your woodworking skills or was that expense that was well worth the money. have they also held up as well as your deck? maybe an annual pressure washing on everything is all you need or do you have to do other maintenence?
glad to hear you would have room for that huge machine in your shop cause i'm still hoping to build a small woodshop to make room for my tools and my shopsmith lathe and planers and shapers that are in storage or that I have to use outside when weather permits.
hope you are having a great weekend!
Doesn’t look very pocket sized to me.
Sad.
Sad.
Flashing behind the band, z-flash on the ledger, and tape the z to the main flashing and ensure the main flashing is a good 6-8” up for snow.
Very cheap compared to your friend’s issue now.
Hard but not impossible, you’ll trip over someone I’m sure , they are out there.This I why I DIY when I can. It’s hard to find someone you can trust.
Agreed, my mechanic is golden…when he has time.Hard but not impossible, you’ll trip over someone I’m sure , they are out there.
DIY, though earns brownie points, keep at it![]()
Very nice. Great score.
With regards to the leak, it shouldn’t happen there, overloaded from the top roof down pipe ?
Another down pipe from above to lessen the volume at that point, maybe.
Good morning, How is the baby? What did you buy(tool wise, toy wise for yourself) . How far back did your friend peel back and did they find the leak?
Any projects, again besides raising another human![]()
You're welcome from the midwest....we shared that fun heat with you...though I think you got it worse as it was at least cooling off more overnight here. Think my high Satu was 100 which was a couple degrees cooler then forecasted and gusts to the low 30 mph actually made it not terrible
