SouthernIllinois
- Joined
- Jan 14, 2024
- Messages
- 1,695
A lot of what looks like dings along the top was in some sort of thick, ancient putty or caulk that was smeared all over the top of the jaws.
Once I got past the crust of it, it was soft but thick and boy was it’s stuck on there good.I was thinking maybe Bondo. the good stuff from days gone by was really hard, and I think got harder as it aged.
Very cool! You did an excellent job!Thank you!
I didn't have to fill anything.
Basically all I did was:
1. Soaked it in Corrosion-X and PB Blaster to break the frozen parts free.
2. Disassembled it.
3. Sandblasted the vise body.
4. Chased the threads with a tap.
5. Used a die grinder to remove rust from the handles and polishing rouge to shine them up.
6. Used an angle sander with 80 & 120 grit to shine up the areas of the vise body I wanted in bare metal.
7. Masked off the parts I wanted left bare metal.
8. Primed it with 2K primer and painted it with implement enamel (Ford Red).
9. Used Testors enamel model paint for the white stripes and lettering.
10. Clear coated the entire vise body.
11. Reassembled it.
The vise belonged to my Grandfather who gave it to my Dad who used it until his death last year. It's more of a sentimental thing than anything. Although I will use it some just because they did, I will probably end up buying a used, big vise for daily use.
Check out how I unstuck the swivel jaw on my Reed 305 1/2 in post #5,343 in this thread. Heat and leverage are your friends!Quick update on getting the Reed 405 swivel base 'unstuck', it worked! Thanks for everyone's input, now onto the swivel jaw! Oh by the way I did break a drag link socket in the process lol!
I fixed the action of the dynamic jaw that used to tighten up after closing this Craftsman 506-51840 vise tight. Earlier in this thread, I got a lot of tips, many of which I used. Thanks GJ!This Craftsman vise is clean, lubed and everything on it looks good and functional. I’ve had the screw out, collar removed, checked the collar bearing and all parts cleaned of old greas and regreased.
However, when I turn the screw handle and squeeze the jaws together just a little tight (against themselves or something in the jaws) it goes from a very easy and acceptable action to open and close, to becoming very tight (to both open and close). I can still open and close it, but the effort to do so becomes much harder.
If I open it all or nearly the way (8.35”) , and then close it.. the action loosens back up to what I think is normal again.
I don’t see any burrs anywhere, the screw is super straight, and the action is normal - opening and closing.. unless I squeeze the jaws together right (not overly tight mind you).
What can I do to fix or troubleshoot this further? I’m using Park Tools Polylube 1000 grease and it’s never been an issue before on other vises.
Thanks for your tips!
Thanks for the validation. I started by adding the ball bearing, spring and set screw for the handle tension (that it had been missing for far too long) — and the rubber washers to prevent any more damage.Stick.. those fat rubber washers some vises use [… on each end of the handle…], and cal it a day...
Maybe use a couple of flat head screwdrivers wedged against the sides? 8” Icon adjustable needle nose pliers? -- Any suggestion (or links) for the type of ring to search for? or how I could fix the ring that I have?
I knew I should have left those in my HJE cart the other day.A couple of smaller cold chisels wedged in should do the trick - screwdrivers you would need to be levering it looks like
I don’t have machining tools. I think off the shelf collars with set screws would be too wide. I’ll keep looking though.FW: that’s a pretty decent sized Starrett vise to be using a clip to hold it in place. I’m not a fan of that design fir some of the reasons you mentioned so once you get it off can you make or find a sleeve with a set screw to make it easier to remove in the future?
BTW nice restoration on your vises!!
Link no worky.This thread addresses what I’m trying to do.
Here it is.Link no worky.![]()
How about an external snap ring? Pull the screw out, take it to a hardware store, find the right one. You will need to install it as you slide the screw back in, so slide the screw, move the ring, slide the screw. Lather rinse repeat.Any suggestion (or links) for the type of ring to search for? or how I could fix the ring that I have?
I measured and the ring would need to fit 3/4” shaft and be 1/8” thick. I’ll keep an eye out for something.. but for now.. it’s fixed!Here it is.
Post in thread 'VISE REPAIR 101 all vise repairs, lubricants, sources for parts and the tricks to fix'
https://www.garagejournal.com/forum...rts-and-the-tricks-to-fix.252830/post-4441397
That looks really great!Just wrapped up restoring my 506-51840 today — this old beast originally belonged to my great-grandpa, and my grandpa passed it down to me a few years back. It’s been sitting for a while, but I finally gave it the attention it deserves.
Went with Rustoleum Farm & Implement Allis Chalmers Orange for the finish — figured a classic tool deserves a classic color. Feels good bringing a piece of family history back to life.
I recently restored one as well. I got all the kinks out of it except for one. For instance, reinserting the slide was difficult, action on the open and close was tight. It’s super smooth now except for one thing.
If I close it tight with or without anything in the jaws.. the action becomes tight. It becomes stiff to open and close vs when it’s normal and super easy.
A firm strike of the nose of the screw loosens it back up. That.. or open it all the way to 9” (almost completely), and it’s loose again.
Any tips on how to fix this ? I’ve discussed this here before, and done all of the suggestions. The striking the nose is the only thing that works, but I’d like to avoid doing that after every hard close.
Screw is retained by a beefy collar with a grub screw.How is the screw retained in the front jaw on those vices? How's the nut alignment, & how's that retained in the body?
Never mind, it sounded better in my head than written out.My thinking would be that the nut is likely shifting slightly & acting as a clamp on the screw. Is there any movement/play on the nut in its dovetail slot?
I had the same problem with a broken Craftsman vise that I repaired. It was a nut alignment issue. Link to thread below.That looks really great!
Well.. my good neighbor said, no charge. Here it is with a little polishing on my part after he machined the jaw and anvil surfaces.
I think area is everything on cost. I think @Beerhippie chimed in recently on what his local shops rate is. But, as @Outlawmws said, a favorite vice is always nice payment, whether it be beer, wine, fish, homemade bread or cookies, just a token if he says no charge, as you noted. Always increases the odds of a return visit. Or return a favor to him of something you are skilled at that he is notWhat would it cost at a shop to have this done? What would be a nice offer to pay for this work?
I offered him a bottle of wine, but he said he doesn’t drink. He said he was happy to help. We sometimes bring his mail in when he’s on a trip and also look out after each other. Treats sometime sounds good.I think area is everything on cist. I think @Beerhippie chimed in recently on what his local shops rate is. But, as @Outlawmws said, a favorite vice is always nice payment, whether it be beer, wine, fish, homemade bread or cookies, just a token if he says no charge, as you noted. Always increases the odds of a return visit. Or return a favor to him of something you are skilled at that he is not
If nothing else invite him for a BBQ.I offered him a bottle of wine, but he said he doesn’t drink. He said he was happy to help. We sometimes bring his mail in when he’s on a trip and also look out after each other. Treats sometime sounds good.
I’m pleased with how it turned out.
