Blade for cutting extruded aluminum?
Fodeman
Rockville, Va
I have a 10 inch miter saw that will handle some Kwik Frame extruded aluminum pieces. What type of blade will give me a fine cut? Extruded aluminum, being pricey as it is, I want to get it right the first time.
PCustoms
VT
Typically I just use a high tooth count carbide "wood" blade.
What's the extrusion look like? Some can be grabby
Rusted Nut
PNW
We cut a bunch of extruded alum with a Diablo alum blade; works really well. Don't cut super fast. I bought 4 blades thinking we'd burn through them, only used one for about 25 threasholds.
PCustoms
VT
Here are the 5 pieces I'm cutting. All but one will accept 1-1/2 material (2nd pic), so that should help keep it stabilized. The 2nd piece (in the 1st pic), I could also fit with a ripped-to-fit piece of wood.
Might be worth buying a blade:
But again, I use my finish wood blade all the time for a few cuts. Keep the open side of the extrusion down to avoid the teeth grabbing, and feed the saw slow and consistently.
Wear ear/eye protection.
F
Fodeman
Rockville, Va
Thanks to all of you. And, PC, I appreciate the safety precautions. I'm a retired industrial electrician, so I'm well aware of safety, especially around any rotating machinery. Safety always!
PCustoms
VT
Lol.
It's worth reiterating, cutting aluminum like this SCREAMS
jack stand
Lakes Region Maine
Hold the piece securely and feed the blade slowly. Clean up the edges with a razor knife. If you really need to, let the blade stop before coming out of the cut.👍
BillK
Beautiful Southern Maryland
The guys next door to me at my business were cutting a bunch of aluminum light fixtures on a table saw last week. I remember he said they found a blade that really worked well. Ill ask them in the morning and see what it was.
F
Fodeman
Rockville, Va
Thanks, Bill
maxpower_hd
Massachusetts
I've cut quite a lot of aluminum repairing tractor trailers with just a Diablo Demo Demon in a hand held circular saw and it worked very well. They arent that expensive either.
BillK
nicks78camaro
Pittsburgh, PA
loganb
Omaha, NE
On painted material, the paint can act like a lubricant. For mill finish or anodized material we try and run coolant as it helps with cut quality, blade life and noise. Shoot a bit of WD-40 on it and see if it makes an improvement
