Which sizes ratchets and sockets for general handy manning household work?
mikey03
Honestly I know theres no right answer here. I am doing more house based handymanning type work and I rarely need any sockets or ratchets for it.
I want something real small and not even a blow molded case because that’s too big for how rarely I’d use it. I want something I can store in a handyman back or bucket. I’ll use the ernst tekton socket twist rails.
Im on the fence about 1/4 or 3/8 and shallow or deep or mid even. I only want one set to keep it small. The Johnny bolts would have needed deep or maybe mid might have worked.
I can honestly make a decent argument for any of them working. 1/4 is smaller and lighter and goes to 15mm which is prob big enough for handyman stuff. But 3/8 can go bigger and maybe I don’t need anything too small. But I can imagine taking apart a washing machine and it having real small bolts.
I was even thinking 12 point maybe there’s some household stuff that runs 12 point fasteners and then I can keep these from getting mixed up with my car tools. If it’s in a house it’s prob not so rusty to need 6 point but maybe it’s something in the yard.
Tekton makes 1/4 impacts up to 17mm which should cover every size I need. And I could run with an adapter on my impact driver in my bag.
what I been doing is have a impact nut driver set but it’s kind of big because each one has its own 1/4 shank and i don’t have a ratchet in the handyman bag.
my limits for this are one single drive of socket and one length. One to two ratchets max. Like a short/reg and a XL flex maybe as a second one. This is something I’m honestly going to use a few times per year so it needs to stay small and light.
Dave455
Sussex, England
You’re right, socket spanners are seldom needed for property maintenance type tasks, but occasionally they are.
Nuts and bolts, in all honesty, are pretty rare. Sometimes you might find them, but if you do they will be common sizes. For me that’s 1/4, 5/16 and 3/8”, or more usually the metric equivalents 6, 8, 10mm. Sockets of 10, 13 and 17 are going to cope with those.
I encounter a lot of coach screws (I think you call them lag screws in the U.S.) and in fact I install a lot of these myself, but if they are hex head they’re mostly going to be 10, 13 and 17 again, maybe a few 8mm.
As for accessories, access is rarely a problem, so a conventional ratchet will work just fine. Maybe a long one will make life easier. I regularly install coach screws with 17mm heads, so I’d preferably want 3/8 drive.
If I needed to do something like repair appliances, then I’m getting whatever tools I need from my shop. Wouldn’t consider those handyman tools.
Consider what “grade” of tools are appropriate too. I’ve got some pretty top end sockets, but I’m probably not going to use them bolting in a fence post. No point.
If I was buying tools specifically for the purpose I’d consider something “mid grade” like this Wera set. Sockets in the sizes you need, practical length ratchet, and things like the hex and torx bits are bound to come in useful. I know these are more costly in the U.S. though so maybe a small Tekton set would be comparable.
I honestly wouldn’t bother with deep sockets. If you really need one it’s a trip to base to pick one up, but most of the time you won’t (or at least I don’t).
I would consider whether I want a set with small parts at all though. If you’re working away from home small parts are easily lost. Maybe it’s a time to consider a few individual wrenches, maybe the “flex combination” style, or maybe the French style, just in the sizes you need.
MiteyF
I don't have a kit in mind, but I'd go 3/8" drive with deep sockets between 5/16" and 3/4". That would do about 80% of fasteners in most US households I'd guess.
Professor Gascan
Maybe that little Icon bit ratchet kit and some HF 1/4 sockets in metric and sae would work. You get a bit and 1/4 drive ratchet all in one.
lolaetype
North Western Arkansas
I've ran into lag bolts and the occasional nut and bolt. I'd buy a 3/8" drive set in inch and metric and a fairly short extension. I've ran into metric in appliances and the only example I can think of is wall brackets for LED TVs. They all seem to be metric.
AEAdam
SE PA
For hex heads I encounter at home, I use Milwaukee hex sockets for my impact driver. I’d go that route. A bit driver, coupled with those bits works well.
Junkdrawer Dog
LV NV
I recently stripped my washer down to repair the transmission. Whirlpool neutral-drain issue. I used 5/16, 7/16 and 1/2 sockets along with a 1/4 nutdriver. The sockets could have been deep or shallow. Either would have worked fine. The listed sizes, along with a 9/16, cover just about all the home repairs I do. Mine are 3/8 drive. You do need a 9 inch and a 6 inch extension for the subject repair.
mikey03
im glad you mentioned the extensions because honestly I wasn’t thinking about that for handmanning though i did use a 12 inch socket extension recently with a balled up paper towel like a dowel to clean out a dirty sink that I pulled the trap out. Was able to clear the sludge off the sides of the drain pipe by pushing the paper towel down with the extension. I could have used anything else but I happened to have the extension nearby
so maybe the longer extension can have multiple use in handymanning
mikey03
Yea that’s in my handyman kit already and got all the torx and hex bits I need. It got the adapter for using 1/4 drive sockets so if I go with 1/4 maybe I pair this with a bigger 9” 1/4 flex ratchet to have two sizes
cody1325
Southwest Virginia
For most household stuff, I really like this kit:
I can put the sockets in my drill, bit driver/ratcheting screwdriver, impact, or even use the ratchet/handle provided (plus a little Klein ratcheting stubby screwdriver that can take the sockets without an adapter--makes an awesome nut driver).
However, I rarely use the flip sockets (and the non-ratcheting "spinner" handle, as I usually just use the adapters with my own handles), and the ones without it (and 3-4 more sockets in its place) are a sizeable upcharge.
Ohio Andy
Columbus, Ohio
What is the smallest and largest you anticipate needing
The Tekton 1/4 set is a nice are from 5/32-8/16 and 4-15mm.
For 3/8 they have multiple sets. If I had only 3/8 I would probably add a wright tool 3/8 small head flex that fits almost anyplace. Part 3440.
The Tekton sets are:
1/4-1 and 6mm-24mm
And
5/16-3/4 and 8mm-19mm
They also sell "common sets"
I really like a specific SK set that has 1/4, 3/8, and 1/2 ratchets no skips regular and deep
1/4 - 7/8 and 4mm-22mm, screw driver bits and hex keys
My main complaint is that this set is heavy.
I have many other sets I like such as subs Craftsman overdrive stuff, wright tools socket sets, proto socket sets...
mikey03
idk honestly I’ve only ever used sockets for handyman work very few times. Lag bolts to hang TVs and Johnny bolts on toilets which I used a pliers wrench since it was available.
i have taken apart a washing machine once but wasn’t able to see anything obviously wrong to fix it.
I feel like for plumbing there might be some stuff like hose clamps but i keep a 6 in 1 driver which has 1/4 and 5/16 (8mm) ends In my handyman bag
maybe a garage door or garage opening might have bolts but the doors are under spring tension and honestly i never worked on them and don’t want a spring to shoot through my chest 😂
if anything i feel like smaller is more needed maybe I got to take apart a coffee maker or ice maker or something in the fridge. On one hand idk what I’m doing alot of times but on the other hand if it’s broke to that level and I’m willing to poke around for free at a family member house they are happy to let me try.
mikedodge
Cheap 3/8 shallow set, done. If you need smaller stuff get one of those sets of 1/4 on a metal strip and an adapter.
For general household work our kitchen junk drawer has a hammer a flathead screwdriver, another with multiple bits and a pair of pliers. Rarely are sockets needed.
Ohio Andy
Columbus, Ohio
Replace the flathead with a 6-in-1, 4-in-1, or a ratcheting screwdriver with bits in the handle. Around the house I need a Phillips at least as often as I need a flat... And that screwdriver is grabbed for getting batteries out of things (usually pH1) so not just the usual pH2.
I still have flash backs of my first cheap 3/8 ratchet that broke on first use and I smashed my knuckles. Thankfully the cheap sets are better quality than that these days... Probably
seber
Deep East Tx.
1/4" flex head ratchet, 3" and 6" extensions, 1/4" shallow socket set and a six in one screwdriver will take care of anything in the house.
roofdweller49
This probably doesn’t duplicate tools you already have. A more traditional pass-thru is also available for the same price with extensions and a 3/8 square drive adapter. Gearwrench, SATA, or Crescent whichever is cheaper. Small footprint.
How are these sockets both metric and sae? Slop in the fit allows it?
Etchase
Hawaii
They are spline sockets, so they do etorx too. They are basically sloppy, but around the house is a pretty good application for splines. Apex doesn’t advertise this capability when they are selling their SAE and metric sets separately, and they are the same sockets as this set.
mikey03
I didn’t realize spline can do etorx
how do you line up the etorx size to a socket size?
KnurledNut
n/a
A standard length 3/8 drive ratchet, a set of standard and metric sockets in deep and shallow, a universal, some extensions, and power adaptors would have you pretty well covered. Eliminate the close enough sizes.
FWIW, I have used more deep sockets than shallow, primarily for bolt clearance.
Uses that come to mind:
Garage doors
Appliances
Foundation bolts
Concrete anchors
Lag bolts and screws
Eye bolts
Machine bolts
Stove bolts
Carriage bolts
All thread
Electrical
Plumbing
HVAC
Furniture
Outdoor equipment like basketball goals, which might have U-bolts etc
Playground fixtures
Pool hardware
Deck hardware
Doors and Windows
Exterior/Interior fixtures and hardware
Stair railings
Tool fasteners like fixing a wheelbarrow
Lawn and garden OPE
A million other uses I am forgetting...
There is always oddball random stuff. I keep an 11/32 deep spring loaded magnetic socket for #8 studs on ventilation applications.
If you plan on repairing water heaters, you will probably know in advance to bring a element socket or anode socket and an appropriate 1/2 drive tool. Then there is stuff that will make you cuss like a square head setbolt on a motor shaft buried in a cage.
In a nutshell, bring what you need. :lol:
mikey03
Sorry for taking so long
Thanks for sharing it but I’m honestly skeptical of it since those metric and sae sizes dont line up that good.
you can use a 7/16 on a 11 but can’t use a 11 on a 7/16
13mm is kinda big for 1/2
Gmonkee
Since I quit full time wrenching to home handyman stuff my kit was reduced a lot. Of the things that stayed on the most versatile were chosen.
DOE wrenches, a small 3/8" socket set and tube wrenches.
I came from a mechanic shop so this is paring down, not building up. Every household task has been covered with only small storage needs.IMG_20260529_083527.jpg
If you use 6pt sockets the size difference in 13mm to 1/2" is not noted. 14mm to 9/16" to 15mm its good to have them all. Differences in fasteners are wildly off to where damages can occur. (experience)
The bigger the size gets from there size differences sae-mm matters less.
