crooney1189
Has anyone used this style foam closure strips? What was your experience? Any tips or tricks when installing?
Looking to seal up the building edges, I don't have any water intrusion (knock on wood) but I can definitely see light coming through all building corners. My thought was to pull the vertical corner trim pieces and install the foam behind them, same with the edges of the metal roof (take out the last row of screws, squeeze the foam under, then put screws back. Would also probably do this at the roof ridge.
I do eventually plan to insulate the building (leaning towards spray foam), but my mini-split will be functional prior to that point (electrical portion will be temporary at the interior), and I just wanted to keep it a little more efficient in the meantime until I can get the actual insulation done. If I can get away with $200 or so in foam strips that will help seal the building better, it seems like it would be worth the effort.
