Question about splicing two wires using a **** connector
Hello everyone
I am looking to splice two wires using a **** connectors (which will be covered by a heat-shrinking tube as recommended). I am completely new at this so i watched some youtube videos and bought the tools already to start practicing.
Anyway, I wanted to ask for confirmation on two things and please refer to below pic:
1. When crimping a wire and a **** connector, should only the stripped wire part be inside the the metal barrel (ie. Green wire in the pic) or should a bit of insulated part be inside it too (Red wire in the pic)? If it's latter, should I try to get the insulated part also crimped?
2. My **** connector has a separate in the middle of it. Could you please confirm two wires (one from each side) don't have to be touching each other or the separator?
I believe the answers are keeping the insulated part wires inside the metal barrel and that two wires don't have to be touching the separator or each other. Any confirmations would be great lol.
Thank you
ericm
Southern Oregon
All the crimp connectors I have used have the crimp on the wire only. The insulation is stripped back so there's only wire in the metal barrel part. If the crimps are solid the wires don't need to touch. Having a wall between the two sides means you can jam each side in as far as it will go and not worry about going too far with the first wire and not leaving enough space for the second wire.
PCustoms
VT
Insulation should NOT enter the barrel (section where it is crimped)
Stripped wire length should allow for full depth of wire with a small gap (if any!) at the edge of the barrel.
What voltage, and where will this be used?
mikedodge
If you put the insulated wire in the metal part you're loosing the metal on metal contact. The wires don't have to touch and usually can't because they're separated. That's what the metal part is for.
What are you using this on?
Codyboy
S.E. TEXAS
Id like to also know what you're splicing
What crimper do you have?
If you're having to practice using a **** splice (sta-kon) you may need to disclose some more info.
alfredeneuman
Fullerton, CA
If it's in a dry environment and the wire you're splicing is #10 or smaller, insulated crimps are the easy way out. (T&B 2RC10 for #10 and 12, 2RB14 for 14 and 16, 2RA18 for #18 and 20)
G
Thanks everyone!
The voltage is 12V and it's actually for my parent's car. I watched a How-To video on youtube but wasn't getting any responses for weeks so I decided to come here out of desperation, and i hope that's ok.
As for tools I bought for this job, followings are the ones. I believe my two wires looks to be AWG 16:
1. Crimping tool for insulated eletrical connectors AWG 22 - 10 (I will be using the Red mark)
2. **** connectors that has a metal barrel with a separator in its middle (I will be using the Red **** connector)
3. Wire stripper (I think i can use the crimping section in this wire stripper but decided to buy a #1 crimper as recommended)
PCustoms
VT
What wire on your parents car?
Those cheap terminals **** IMHO. The plastic is stuff and breaks down.
Thanks everyone!
4xdog
Santa Fe, NM
Those bits and pieces should work fine on a 12V **** splice.
But what wire, and especially what circuit, are you splicing? Good crimps will be fine on almost any 12V circuit, but when I've removed previous-owner car alarms on two Tacomas now, I've soldered the main ignition circuit wire when I've rejoined the ends cut for the alarm.
A **** splice probably woulda been fine -- I've done LOTS of them -- but for a critical circuit that doesn't see any strain behind the intrument panel, I feel better with a soldered connection.
whateg01
doo dah, kansas, usa
Everything I've ever read and been taught was don't use crimpers that poke a hole in the insulation to crimp. Insulated connectors are supposed to be crimped flat-ish. The crimpers with the prong are meant for bare terminals.
Bert_
NW Iowa
I've used those ratchet crimpers. Not fond of a flattened out connector.
I prefer these for insulated and non insulated connectors. Seems to give a better crimp than just mashing it flat.
I use them too. A flat crimp just isn't good. Who cares if it pokes a hole in the insulation? These kind of crimps aren't sealed anyway.
G
Hello,
So it will be for this part called 'high-pressure fuel pump adapter' in my parents' old car. As this below video explains, older models apparently require cutting out the existing old adapter then splicing with a new one.
I planned to use that **** connector for crimping (splicing?) wires then also using a separate heat-shrinking tubes or electrical tapes over it to shield from waters.
G
Thanks Cody,
I think this section in the wire stripper tool i bought is for non-insulated connectors so i will try that out later.
G
Hi PCustoms,
Do you have a suggestion on which brand have good terminals/connectors by any chance? I found those on Amazon and they all have a good review and look the same.
I thought about using a heat-shrinking **** connector but i worry that may be damaged over time because the wires i will be splicing are right near the engine.
PCustoms
VT
Hi PCustoms,
Tyco
What car? Why are you having to crimp in a new high pressure fuel pump adapter?
And lastly, do your parents know what you're doing?
kbuhagiar
Escondido, CA
Tyco
I had the same question and then I skimmed through the video.
They need a new fuel pump, and apparently the only replacement fuel pump available is a later version that is not plug-n-play and requires a slight wiring modification.
niget2002
Josephine, TX
They sell waterproof connectors that will shrink with heat after crimping. I'd get those instead of trying to use heatshrink over cheaper connectors.
Codyboy
S.E. TEXAS
Ok. The flat ones don't make as good of a connection.
**** connectors are made for low voltage and I've never had an issue with a crimper that damaged the outer insulation on the connector.
If its an outdoors connection I either tape it or shrink sleeve it.
Non issue in my opinion.
kbeefy
Harington, Eastern Washington
Hello,
If your gonna put heat shrink on the connections anyways (I would) then ditch the insulated crimp connectors and use non-insulated ones. If you already have the plastic insulated ones, it's pretty easy to cut the pvc insulation off of them and just use the barrel from inside of it.
Get some heat shrink with adhesive in it, it's often advertised as waterproof.
Alternatively, you can get the 'crimp and shrink' style **** connectors. They work fine but just don't look quite as clean.
As far as the crimp, all good info above. Insulation stops at the barrel.
Sumboodie
AK
If I had a nickle for every connection I've made, I'd be a rich guy!
I use bare connections and a good adhesive lined shrink tube.
kaymccampbell
Upstate New York
I know we're all excited about crimping connectors, but has anyone mentioned the self soldering and shrinking **** connectors?
https://www.amazon.com/Connectors-H...therproof/dp/B08F46WKCZ/?tag=atomicindus08-20
PCustoms
VT
Sorry, those are a gimmick IMHO.
Either properly crimp it or properly solder it.
75gmck25
Alexandria, VA
Since you mentioned engine heat, you might want to see if you can find some of the heat-resistant fabric protective sleeves GM used to use on wiring. I have a sleeve on the wiring for the temp sensor on my SBC, since the wire has to go down between the exhaust manifold ports and connect to the temp sensor.
This is one example, but automotive versions might even be on the shelf at the parts store.
LeonardY
Southern California
Not those in particular. I used ones from Mcmaster in the parks. They held up well.
kaymccampbell
Upstate New York
Not too gimmicky. I just checked back, and I used those to do the rectifier harness on the Burgman, 5 years and 15K miles ago, when I chopped it. And they're right to the left of the rear wheel, and get plenty of road splash. When I cleaned the the Burg for the start of riding season, other than a coat of road crud, they looked like new.
JeepYJ
If you want to increase your chance of failure, buy a bunch of junk from Amazon...
There are quality connectors and tools
on Amazon too. Give the OP some suggestions on better/best products to use.
Bert_
NW Iowa
I buy ideal or ilsco for cheap crimp connectors. Those are known brands. You can get a decent crimper, Ideal, Klein and Channel lock all sell the same one pictured earlier. The crimper is like $35 so still low cost.
G
Thanks everyone.
Just out of curiosity, is 'Ever Start' a good brand? I saw it at Walmart store yesterday and I thought about buying them. They had both regular connectors and also heat-shrinking ones.
Anyway, I will keep you all updated. I may do it this weekend if i feel ready and the car part arrives. If not, definitely next week.
mike93lx
Richmond, VA
Thanks everyone.
Everstart is a brand that doesn't make anything.
For connectors, I like 3m, but they can be hard to find in small quantities
