Oggy
I hit the button for the overhead door into the garage this evening and it opened up no problem.
I hit the light switch and one led (T8 style, direct wired, in the middle of the garage), and one fixture of T8 fluorescent bulbs lit up. Confused, I shut them back off and flipped the switch again, same thing. I went to the breaker box, flipped it off and back on, now nothing works. No pops, hums, sparks, or anything else out of the ordinary beyond the lights not coming on.
The breaker box is a sub panel, feeds only the garage. There’s 4 breakers right now, one for the lights, one for the GDO, and two for receptacles. Receptacles work (atleast one set - I have a pool pump running), the gdo is ok. The receptacles have a gfci, but I’ve never seen one for the lights.
Power comes out of the panel, into the switch and feeds the first light fixture right over the garage door, from there, about 9 other fixtures are fed, each with 4 bulbs, all but 3 fixtures were converted to LED from fluorescent in April with the ballasts removed at that time.
Is it the switch? (I’ll start here tomorrow)
Is it my wiring? (Write up here: https://www.garagejournal.com/forum/threads/swap-out-ballast-for-led.545394/)
Is it something else?
What gets me is that the first time I flipped the switch a few of them lit up. What could allow fixtures in the middle to light up when they’re daisy chained but not the rest?
