Hobby_Man22
If i laid a tarp under it could I yank it all off with my tractor? No way I'm shoveling it off.
I dont have a big enough tractor for that. That would be a good job for a telehandlerSure. Just turn the trailer on it's side when you get home. Upside down would be even faster.
(absofrickenloosly not)probably not
On a serious note, maybe if he got the tongue high enough it might work?Sure. Just turn the trailer on it's side when you get home. Upside down would be even faster.
Tractor with FEL?If i laid a tarp under it could I yank it all off with my tractor? No way I'm shoveling it off.
How big is the trailer? Shoveling off a trailer isn't as bad as shoveling onto a trailer, you have gravity on your side.If i laid a tarp under it could I yank it all off with my tractor? No way I'm shoveling it off.
Nope.If i laid a tarp under it could I yank it all off with my tractor? No way I'm shoveling it off.
You also know the job is half way done.How big is the trailer? Shoveling off a trailer isn't as bad as shoveling onto a trailer, you have gravity on your side.
Why do ya'll continually post things to make me spend $$$.Many years ago I had to move a big pile of dirt from my parents property to mine. I used a Loadhandler on my flatbed trailer that I modified with some 2x8's on edge to form a "chute" the width of the Loadhandler's drag sheet. The trick is to make the surface of the trailer deck as slick as possible so I fastened some hardboard (pegboard w/o the holes) smooth side up at the bottom of the "chute". It worked pretty well and I quickly found the amount of dirt that I could unload by cranking the Loadhandler. I hauled about 15 loads which were about 4-5 buckets worth each on my front loader. Today I have a dump trailer which makes hauling/dumping a lot easier.
Loadhandler Pickup Truck Unloader - Heavy-Duty Full-Size Truck Bed Unloader
Spare yourself the backbreaking work of unloading anything you may haul in your pickup truck bed. Unload your cargo faster with Loadhandler.loadhandler.com
In recent years I have switched to paying someone with a dump truck to haul and dump that stuff. They can bring something like 10 of my pickup loads in one trip, and I generally end up using a bunch more than I originally estimated.Why do ya'll continually post things to make me spend $$$.
Very timely 'find' since we are hauling loads of mulch for flower beds and soil to fill holes around our 'yard' where stumps have rotted away.
The last free dirt I got was from the county cleaning out the ditches.In recent years I have switched to paying someone with a dump truck to haul and dump that stuff. They can bring something like 10 of my pickup loads in one trip, and I generally end up using a bunch more than I originally estimated.
Like dejavou.Disconnect trailer from truck
lift trailer tongue up with tractor bucket
Essential making a dump bed, you might have to reverse some to get the dirt to slide off
Like dejavou. I think i said that yesterday.Tractor with FEL?
Heavy plastic in trailer, dump dirt in.
Get home disconnect trailer from truck where you want to dump dirt.
Lift front of trailer with the FEL.
ETA
But if you have a FEL just use the bucket to unload it.
Same, except it's my dumptruck. Well, actually have 3 of them.One of my neighbors has a dump truck. That tends to be my answer for anything requiring bulk materials...
