Free fill dirt loaded onto trailer
Hobby_Man22
tx
If i laid a tarp under it could I yank it all off with my tractor? No way I'm shoveling it off.
H
Hobby_Man22
tx
Sure. Just turn the trailer on it's side when you get home. Upside down would be even faster.
I dont have a big enough tractor for that. That would be a good job for a telehandler
58Yeoman
Central IL
I used to do that with my landscape trailer. Then I bought some heavier sheet metal and welded it in which made it easier to shovel out. THEN I bought an end loader for my JD X738 which made it even easier. I can get most of it with the endloader, then finish it with the shovel.
kaymccampbell
Upstate New York
If you had a heavy enough tarp you could. I had a tarp n crank thing that would unload a yard of dirt from my pickup truck.
Nowadays, I use the Dingo as a weight to drag out a tripled tarp laid in the trailer. You can't actually move the Dingo after a foot or two, but the car will pull the trailer away just fine.
Copymutt
Colorado
I use a 16” steel plate w/ a couple of U bolts to fasten it to my backhoe bucket teeth. Easy to scrape out the material w/o hurting the bed.
Higgy1300
Florida, Space Coast
i had 1 bucket of an endloader put in my colorado, first i laid a tarp down, then put 5 gallon buckets in the bed. after i dug the buckets out and some dirt i was able to pull the tarp out. had it been just the full load i dont think it would have worked
75gmck25
Alexandria, VA
In my experience with a loaded 8 foot pickup bed, the fill dirt packs down and would be really difficult to slide out. I tried using a tarp under it, but the best I could do was use the tarp to pull the cab-end end layer of dirt toward the tailgate as I slowly pushed the dirt down onto the ground. It didn't really help that much.
elmer
Detroit
Pick-up truck bed mat would work better than a tarp. Still not gonna be moving much dirt like that.
customh
East Bethel, MN
My Dad and I hauled off a bunch of landscape rocks by arranging 3 pieces of plywood (roughly 2.5' x4' in the truck bed. Each one had carriage bolts and nuts with short lengths of chain that held it to the next so it would act like a hinge between each piece. Attachment points on the tailgate end piece hooked to a tree or a tractor in your case. Pull/dump the assembly and remove at each hinge so you don't A: snap the plywood when you dump and/or B: bury the plywood when you dump.
Renegade1LI
long island ny
I had a guy at the quarry flag me down last year as I was leaving. Said they wouldn't load his flat trailer, he had a tarp on it also. Ended up buying my 5yds of crusher run & paying me to deliver it, worked out well for booth of us. Since then I have delivered a couple of loads to him & a neighbor, more fun than the money. Just saying you probably could get a local guy to deliver it for a small fee.
Codyboy
S.E. TEXAS
Tractor with FEL?
Heavy plastic in trailer, dump dirt in.
Get home disconnect trailer from truck where you want to dump dirt.
Lift front of trailer with the FEL.
ETA
But if you have a FEL just use the bucket to unload it.
mikegt4
sw ohio
Many years ago I had to move a big pile of dirt from my parents property to mine. I used a Loadhandler on my flatbed trailer that I modified with some 2x8's on edge to form a "chute" the width of the Loadhandler's drag sheet. The trick is to make the surface of the trailer deck as slick as possible so I fastened some hardboard (pegboard w/o the holes) smooth side up at the bottom of the "chute". It worked pretty well and I quickly found the amount of dirt that I could unload by cranking the Loadhandler. I hauled about 15 loads which were about 4-5 buckets worth each on my front loader. Today I have a dump trailer which makes hauling/dumping a lot easier.
txvwnut
Bedford, Texas
I did a load of mulch with a tarp and my ratchet straps under it. Hooked the long end of the straps to my forklift and pulled it out.
Hooked
League City, Texas
Why do ya'll continually post things to make me spend $$$. :)
Very timely 'find' since we are hauling loads of mulch for flower beds and soil to fill holes around our 'yard' where stumps have rotted away.
Fixr
SW VA
In recent years I have switched to paying someone with a dump truck to haul and dump that stuff. They can bring something like 10 of my pickup loads in one trip, and I generally end up using a bunch more than I originally estimated.
Codyboy
S.E. TEXAS
The last free dirt I got was from the county cleaning out the ditches.
It may not be the cleanest dirt but it's free and they will dump it where you want it if they can get the dump truck to that spot.
I got about 30 loads (small single wheel dump) of I'm guessing 4 or 5 yards a dump.
Will make for good berm dirt for the range.
Dig Doug
Disconnect trailer from truck
lift trailer tongue up with tractor bucket
Essential making a dump bed, you might have to reverse some to get the dirt to slide off
Codyboy
S.E. TEXAS
Like dejavou.
Tractor with FEL?
ETA
Like dejavou. I think i said that yesterday.
madison069
Monroeville, PA
I have a tail gate attachment that helps unload the truck faster by rolling a sheet of fabric out on the floor of the truck and dumping the dirt/gravel/mulch onto the fabric. I do place a trap down first to do two thing; reduce the friction between the fabric and truck bed protector mat and catch the loose dirt that goes off the fabric sheet. I've hauled and unloaded a cubic yard of 2B Limestone this way and usually have no issues.
This is the exact one and mine is over 8 years old.
Found a photo of when I hauled some stone with it.
