Beerhippie
When painting metal, I generally use Rustoleum without primer. I've found in the past that the paint tends to chip off at the surface of the primer, where an unprimed finish would just show a scratch.I agree with Beerhippie.
After stripping off old paint, I wash with acetone and always use primer before the finish coat. Do you guys use primer or just shoot a few coats of the finish color?
One of the reasons I use primer is to do a final inspection of the surface. With a uniform coat of primer, any flaws that I want to deal with are then more noticeable. Plus of course, adhesion is supposed to be better with primer.
I use sanding primers where needed.
