Torque wrench storage
Rusted Nut
PNW
Well, that explains why I can't find it. I knew they had a smaller wrench, but for some reason I thought it was 1/4" drive.
I use to have a HF 1/4” drive torque wrench, it broke. All my other torque wrenches sit loose in the drawer with ratchets, etc… They stay calibrated.
A
AJHD
*Off-topic*
Picked up a CDI 752MFRMH on Zoro with a 20% off. It arrived today.
Have to say, I'm not terribly impressed. I'm sure it will work, but initial impressions are not great.
The desiccant package left a white powder everywhere, I had to wipe down the inside of the case and the torque wrench.
There is some discoloration just below the head. Although I'm sure it's cosmetic I will likely snap a few pictures and send CDI an e-mail about it.
Which brings me to the real disappointing part, the head. The ratchet mechanism feels cheap and terrible. I know it's an older 36-tooth design, but wow. Not a fan of the selector switch. The anvil is also loose and has some movement. I will likely ask CDI about this as well.
I wish there was an upgrade kit.
Schurkey
In open, unlatched blow-mold cases in the top drawer of the toolbox. They got used so much for about ten years years, that the "hinge" of plastic on the cases were degrading/tearing. Hadda tell folks to NOT close the case and latch it, just turn the torque down, set the thing inside and walk away.
These are Mac-branded, micrometer/clicker 3/8" and 1/2" wrenches purchased in the 1990s; and which aren't used that much any more. The others are "government surplus", kept in latched, metal cases, and hardly ever used--like once in five years, maybe.
Snapped-off
Indiana
*Off-topic*
Here's the part number for the upgrade kit: QD2R75A or if you want the flex head: QD2FR75B. :thumbup:
A
AJHD
No thanks. The price tag is why I bought the CDI.
But, I'm returning the CDI and I will probably pick up an Icon to replace it.
The Icon feels like a $500 Snap On, whereas the $150 CDI feels like a $20 Pittsburgh.
Sumboodie
AK
Most of them on a shelf, rarely used tools go there.
The couple I use often sit on my box in their cases or in my box naked.
Sumboodie
AK
I have the Gear Wrench versions. The 1/2" is pretty good. The 3/8" I'm not a huge fan of. I have to read the instructions any time I use it, it's not user friendly at all.
And after a torque it has to "reset" and takes like 10-15 seconds.
Was doing something with quite a few bolts and threw it back in the case in disgust and used my 25 year old Craftsman clicker. Done in the time that turd did 3.
The 1/2" doesn't have that delay and is easy to use. No idea why they didn't use the same setup.
Was almost $200 too.
A
AJHD
@Sumboodie I assume you're referencing the digital versions? I'll stick to click type and split beam. Already picked up an 3/8" Icon click type to replace the CDI I sent back to Zoro.
PT Doc
All torque wrenches in their cases, especially the 3/4”. I have been known to ns’s every now and then and wouldn’t want a precision tool to get bonked.
Semi-hole mechanic
The 3/8” and 1/4” clickers are in their blow molded cases in a drawer in the tool box, the old CMan 1/2” bending beam is loose in the same drawer, I really only use it for lug nuts and such.
