Not the right shape for a typical caulking iron for a boat, to scratch one potential off your list.I’m thinking it could seat something into a channel or maybe work softer metals on a form.
I'll gladly double your money!
October of '45, BTW, was the end of the War in the Pacific.
You'll need to remove the old, fossilized gasket first. Screw the cap down as tight as you can (without damaging it) and give the screw in the center a goodly snap o' the wrist with a well-fitting screwdriver. Might take a few tries. That will separate the inner part of the cap with the gasket from the shiny bits. Throw that inner bit into the campfire or use a torch to get it to about glowing hot, then douse it in water--that usually blows the old gasket out. Use a small screwdriver or toothpick or whatever and scrape it clean, then install the o-ring from the hardware store. The o-rings that don't specify Viton are almost always Buna-N, which is just as good for this use.
Help ID-ing this ornate “chisel” that was in the little green box yesterday. It’s currently3-1/4” long.
A box of Coleman goodness for $6! Lantern, propane lantern, burner, spare parts, and lots of mantles
to Timm's USUCK! Pick almost anything in the Coleman pile and the rest is free! I'm counting at least a dozen packs of mantles - are they all Silk-Lites?Now for the bad news: Like any "roarer" burner stove, it has two settings: Thermonuclear and off.@Outlawmws Ooof agreed, don't start it inside your car. It certainly makes it presence felt when lit. Replaced the o-ring and fired right up. Rolling boil lickety split.
That's a YOU **** score! The mantles are easily worth far more than you paid. I'd like to see the generators laid out where I can see what they're for, but figure each one is worth more than you laid out.
The big-hat lantern... definitely needs more and better pictures! From the knurled, screw-on pump cap that appears to be steel and fuel cap that also appears to be steel, (magnet test) 228C from '45. It should bear a US stamp on the bottom, though. It should also have a large, yellow decal below the valve.
Oh, ****--Coincidence Control Center is working over time! I went to look for pictures of a similar one I have--and it's the exact same date!
!!!! October of '45, BTW, was the end of the War in the Pacific.
Thanks for the info … honestly, I haven’t paid much attention to Coleman Lanterns until the GJ pushers … errr influencers … started posting!!I'm thinking its part of a really old lock mechanism.
I was hoping for Elton John bluegrass but then I noticed the Jim Croce title above and realized they were stacked.Did anyone else not realize the books were stacked for a second, and wonder how exactly Elton John sounds in the style of Bluegrass Banjo?
Man, now I so want to hear the banjo version of Stan with Eminem live at the Grammys. To think one of my favorite live performance of all time could have been even more interesting!Did anyone else not realize the books were stacked for a second, and wonder how exactly Elton John sounds in the style of Bluegrass Banjo?
Damn. I'd buy a Bluegrass album by Elton John and Jim Croce!I was hoping for Elton John bluegrass but then I noticed the Jim Croce title above and realized they were stacked.
a mystery wood chisel
Nice find!found this old school parts/nail bin for $10. Fills from the top for each of the 12 sections.
You ****!Couldn't reach for my wallet fast enough at $50!
I already had most of this set in two smaller Craftsman Kromedge kits but this beast has the elusive12-20(Stanley guys will recognize that thread). [Edit: it does NOT have the 12-20 tap/die, darn it) Still, I wanted one of these so bad when I was a kid working at Sears in the 90's but they were like $300 even back then.
Yep, you ****, too!The cashier says "How bout $25?"
Nice! I've got a couple myself.I picked up a Gerstner in need of work for $15.
Didn't realize that the Leatherman super tool had locking blades. Snapped it open and was stumped on how to close it. Turns out you open another blade partway to unlock the blade. Go figure.
Oh, yeah, you ****!Had to take my wife’s car in for a check up after the trans was rebuilt. The shop was in an area I don’t get to often and I stopped at a different store ran by an estate company on the way home.
It was packed full of….everything. Like no aisles, move stuff to walk through.
Unfortunately it is not organized at all. They seem to take a house worth of stuff and dump it in a pile and move on to the next house. Looking through stuff felt like cleaning and organizing, but for someone else, and then you pay them.
I did manage to find a couple small screwdrivers, a rotating hardware organizer with jars full of hardware, a 13mm SK wrench, and way in the back on the floor, behind a rack of clothes and under a dining table, this 6” Buffalo Vise. $50 for everything.
Yesterday I stopped at one of my regular thrift stores and found this whole box of laboratory glass. Marked $20, but kitchenware (how they had it labeled) was 50% off. $10 out the door, minus my 22 cents in rewards credit.
That’s awesome!
Estate sale ($9): Coleman 530 Pocket Stove (B46) w/ funnel and wrench:
- Heading into the Canadian Rockies so I might as well haul it along for making coffee. Unfortunately not pressurizing. Figure I'll soak the leather gasket in the pump with oil and change the o-ring in the cap. Hopefully, that will do it.
***** to 3bay and bmw. I've had other things to do and missed the last two weeks of sales.
