I'm considering moving my home office into the loft space in the garage building.
The building currently does not have any insulation or plumbing, but it does have electricity.
My concerns are primarily about heating and cooling. We live in northern NH, so it may not rise above freezing for a couple months at a time. Conversely, it's about 80 degrees and sunny out right now, and my garage loft is well over 100 degrees.
Questions for the group from a noob:
1. Am I correct that my garage loft appears entirely unvented? I'm not seeing any ridgeline vents or soffit vents. Do I need these? Why wouldn't the building already have them?
2. What should I consider for cost effective insulation and cooling of the office space? I'm planning on taking advantage of the windows here, and I would consider adding a skylight or two on the south-facing roof for sunlight and passive solar heat in the winter? I'm also guessing a small mini-split is the way to go for cooling.
3. The unknown-unknown. I'd appreciate any advice or things I need to know before I go too far down this rabbit hole?
