WoodsTruck
- Joined
- Jan 12, 2013
- Messages
- 1,025
I have a bad habit of digging through the scrap bin at work. I like to have various sizes of round stock to use in the press. Seems like I can usually make something work.
I have a small surplus of anything the machinist throws out. He’s taught me to Dig out old rusted out pipe studs for when I get a small mill/lathe and make my own spacer plates, rods, whatever.I have a bad habit of digging through the scrap bin at work. I like to have various sizes of round stock to use in the press. Seems like I can usually make something work.
Thanks Marc. Not sure why I stalled out for so long on doing them. The CNC capabilities really improve quality.Door panels turned out great!
Thanks Dave. The seat was a bit out of place, now with the doors matching it's coming together.The interior is really looking nice !!
Thanks Mike. I'm still working on slowing down, enjoying, and making a better product.Phenomenal job Justin. Just excellent workmanship.![]()
Do you have a complete set of cad files to send me? hahaWhen can you start on the 4 door panels for my Wagon(eer)?
What type of overall design style are you going for? Key elements?I am willing to jump right to the interior on my unfinished '32 if you're interested and available...![]()
No, but give me a couple of days. What file format?Do you have a complete set of cad files to send me? haha
Shagadelic!
What he said!! I'm continually impressed by your willingness to tackle just about anything!Phenomenal job Justin. Just excellent workmanship.![]()
CO2 or Fiber?Looking at a low cost laser for use on CNC table. Use would be engraving and perhaps cutting foam or fabric.
Can get a 5W air assist type for under $100. Anyone done this?
Generally speaking, foam from an upholstery supplier will work well with adhesives. For a dash pad you want either XLPE (cross linked polyethylene) or closed cell landau top foam. The later is definitely at any upholstery distributor. On the landau you want to scuff both sides with 80 grit. It has a skin on it and the adhesive won't bond to the skin. A few passes with 80 grit sanding block does the trick. Either foam can be shaped with round over router bits, sanding, etc. The denser XLPE has very little give, like an OEM dash.I looked around at the foam at the upholstery shop. There were a few types and I didn't know what I wanted so I didn't buy any. Now I wish I had.
The foam adds some more complexity. Not sure how the foam would react to the glue, it melts the foam in the rigid boards. So plan to just do the best I can with what I have. The pad is really past saving if perfect is the goal. Would be time and money ahead to buy a new pad and cover it. but perfect is not the goal of this truck. I'll do a 90% job, as the last 10% is 90% of the effort. The end product will be much better than the wavy plastic cover, and the matching fabric should bring it all together.
