Do I need a filter for my (air) regulator?
Garatzis
Hi,
A little background: I'm a bike mechanic who's making a little shop in my brother's attic (he has a car shop with an upstairs room he lets me use). I'm planning on running a 50-foot hose from his air system up to my space. His air pressure is too high for my needs, so I want to get a regulator to dial it down a bit.
So, do I really need to get one of those filter-regulators for my point of use? Or can I get away with just the regulator? Most of the time I will be inflating tires and just blowing stuff off for cleaning, but I plan on using an impact wrench and a little die grinder sometimes. I mean, by the time the air passes through about 80 feet of his copper pipes and then my 50-foot hose (some of it "uphill") wouldn't the air be cooled and dry?
Any related insights would be greatly appreciated too. Thanks!
G
Garatzis
for your mentioned needs, a filter is not necessary , although it wouldn't hurt
Should I put in some sort of vent valve to bleed off any water? There won't be much of a "drop." The hose will go up a story and then straight across a wall, after which it'll likely drop straight down about a foot or so to my point of use.
BillK
Beautiful Southern Maryland
