Grant Gunderson
Hey guys, I’m in search for a bearing puller that would fit these 22mm OD bearings.
This is the easy one as bearing separator should work, but I haven’t found one thin enough to slide into that gap to separate it.
This one is trickier. Once again bearing OD is 22mm and gear ID is only 38mm so very little room to get a puller in there.
Off hand I’m thinking an exterior collet type puller could work similar to a dowel pin puller, but the 22mm diameter is an issue for those.
