Beerhippie
Far NE Oregon
Mostly, trying to stay in the blast of the swamp cooler. We're in a extreme heat alert condition, so I'm trying to follow the rules:
Stay inside in a cool place (the shop is cool, regardless how hot it is).
Avoid strenuous exercise--not a problem.
Drink plenty of fluids. Just checked, and, yep, beer is still a fluid.
oldman_pottering
Tinonee, NSW Australia
Today, I finally decided to complete the refurbishment of my catalogue #1426 1938 Delta Finishing sander with the period correct 864 Miter gauge and machine stand...
Before
Today
Spins up like new... This was a very satisfying salvage job...
I was forced to get this finished because it will be used to fine tune the 384 miter cuts needed for the trim on the garage door panels...
Putting her back to work as she should be...
Looks brilliant !
2001ZR2
Kansas City
Didn't make that much noise until I pulled the ABS fuse. Was locking up before with the fuse but afterwards it ok until low speed. Will new rotors and pads....a pad slap isn't an option. The warrantied battery showed up and was installed.
The Suburban has made its final stand resisting getting on the road. Rear brake hose fell apart when the mechanism touched it to inspect. What I thought was a braided line for the rear was in fact a front left hose. Will be put on to match the front right hose.
My wife made to Des Moines but said the engine was ticking and there was a flashing light on the dash. Asked to pull over and check her oil level stupid AFM system uses it. Determined the she was at least 2 quarts low. She topped it off and engine noise gone. She now knows what check gauges light looks like. And that the driver should check fluids BEFORE hitting the highway.
Did hit an estate sale and got 12 wrenches for about 3 dollars each and a handle and Plomb claw hammer head for 3 more dollars.
69charged
carberry, manitoba
Ah yes. Looks familiar…..
Changed rear brakes on the son’s dodge today. Caliper pin seized and took out the back side pad right to the metal and then took half the rotor off!! He said he didn’t hear anything. Right……
imagineer
Not the only thing I worked on over the weekend, but it addressed an annoying issue with the HF 12" Press Brake.
Among my workshop activities were several occasions to use my HF 20T Hydraulic press. Some of those occasions required only the press, and a few required the used of a 12" press brake. Whereas the press brake works fine for what I need, it's a pain having to move it onto and off of the 20T press. There's just no convenient way to pick this thing up.
I had a little time left before calling it a day, so I bent up some 3/8" round bar into handles and TIG welded them to the base plate on the press brake.
rcktpwrd
Raleigh, NC
Spent a couple hours sweating profusely in the garage earlier changing out the rear leaf spring shackles from 'stock' ones to shorter 1" lift ones. I had to use a step bit to clean/open up the bolt holes a bit, mainly to clean out the powder coating. One zerk broke off, I was able to remove the broken part and install what was left of it but the spring and ball disappeared, otherwise a fairly straight forward parts swap.
The truck has a flip kit in the back so it sits 6-7 inches lower than stock but the original 200+K mile springs are pretty worn out so any load in the bed makes it sag and there is very little suspension movement left. On the plus side the worn springs make for a softer ride so I'm not too eager to replace them plus that's a big pain in the ***...
Mike65
Horse Pasture, Va.
Last week the driver's side power window regulator broke, the new one was delivered this morning. It took me about 1/2 hour to replace. The door panel was a different story, after fighting with it for 1/2 hour in the heat I gave up & will try again tomorrow. At least the window is fixed.
Too bad Air shocks are not readily available as the were in the past. I put a set in my 64 Ranchero as I routin;ey put heavy laods in it (I also put a 9" rear axle in it)
rcktpwrd
Raleigh, NC
So, there is an air bag assist kit that is a bolt in for these trucks, but it doesn't fit due to the width of the rear wheels...
69charged
carberry, manitoba
Beautiful truck. I grew up dreaming of owning a lowered 90’s Chevy. My dream was an extended cab long box with dually fenders and fatties under it. I still have a picture of one I wanted to copy framed somewhere in storage.
Thanks for the memories.
Found one similar. But the picture I have the truck has tapered stripes painted on it. And it’s black and purple.
The girls would have been optional!! 😂
Beerhippie
Far NE Oregon
I never got the lowered-truck thing--but I'm a country boy who'd rather be out bashing around on dirt roads and tracks. I have no use for gigantic lifts, either. 8-10" of clearance is fine where I go. Not sure why you need 37" tires to get groceries at Safeway.
A truck with no dust and no brush scratches... something just wrong there.
It's now 90F in the shop again, with the swamp cooler going full-blast. I don't handle heat like I did as a young man.
I'm withTimm on the lowered truck and mostly useless for my uses. I convinced a friend to NOT lower his 59 Ford PU and instead convert it to 4WD. It was an awesome truck and I should have bought it when he offered it to me, but I didn't
One lowered truck I DID appreciate was a car hauler flatbed, used for a California Super modified (open wheel winged cars) and the bed was just big enough to hold the car. by being lowered it was easy to load the car.
Snip's
Did a little bit of nickel plating in the garage today...
I have a column lock handle for my Delta DP220 drill press that was rusty...
It spent a day in my DIY rust remover...
Then wired it up for a dip in the nickel plating jar...
Chilling in the green bath...
A bit of hand polishing with some Mothers Mag & Aluminum polish...
bulletpruf
San Antonio
Stihl 026 Pro got used for several hours last week, so I cleaned it and blew out the air filter, sharpened the chain, took down the rakers a tad, cleaned and flipped the bar, and topped off the oil and pre-mix. Nice little saw and plenty of guts; I took 5 saws total to the job and the rest stayed in the truck.
Old Man Roger
Palm Coast Florida
I'm thinking more like recreational mescaline. Where's the engine of the hauler? Between the seats? Why that HUGE forward overhang? Why a road-car underbody instead of a truck? The wasp-waist? So many questions....
Imagine it being a car with a truck cab stuck out in front. My guess is the engine is in the same place it would be if it were still a car. Somewhere between the front wheels, behind the cab.
Beerhippie
Far NE Oregon
But, then, wouldn't it make more sense to put a truck cab on a truck?
I'm sticking to recreational drugs as a theory. Look at those twin-bubble, negative-rake rear windows on the hauler--great if you want to see if the car is still there, but not for much else.
Ducky
Southeast, Alaska
Man I hear ya. I ran a few errands before heading to my shop. By the time I got there, it showed 67 on the inside thermometer. I did what I could but by the time it hit 70 inside I was like, enough already! Had to sit down, grab a beer and contemplate my progress for the day (hours). I'll try again tomorrow. it's supposed to be in the mid 60's.
y'sguy
Tulsa, Oklahoma
After messing around with my car a few weeks ago with a starter replacement, it resulted in what seems to be a miss. I've checked all the connections and made sure I returned the plug wires to the correct order and all the other stuff I could think of.
This evening, I went back out to the garage and pulled each spark plug on the passenger side and inspected and cleaned them. They didn't look bad to me. BUT, after reinstalling, I think it may be fixed! Did a drive around the hood, and the miss seems to have disappeared. Hope so. I'll check again tomorrow. I'll also go ahead and do the driver'sIMG_2794.jpegIMG_2802.jpegIMG_2801.jpegIMG_2801.jpeg side.
nadogail
Coronado, CA
Assembled 80% of four small planter boxes that will straddle balcony railings. I have the fixture that aligns the sides and bottoms all "dialed in" and will cut more end and side pieces tomorrow.
Getting better with the brad nailer, fewer misaligned brads.
Made an adjustment to one of my shop stools so I can cut pieces to length while seated.
