Drilled a corrugated piece for brackets to put a little roof over the yard tools.
Killed a few mosquitos with my electric swatter. I'm finding it easier to nail them with a steady motion rather than a quick swat.
Bed liner can do wonders to hull leaks.Ya'll got auto bilge pumps on ya'lls boat?!?!
I really need to look into an auto bilge pump, but the bilge pump I have still works. I just have to remember to turn it on while fishing.
What should happen, is I should find the damn leak in the boat. The water was coming from the right side of the boat, but I couldn't see it directly due to the metal cover of the foam section of the boat was hiding the leak.
I'm thinking more like this.Kill them with lasers...
Leonard, You need one of these... Photon matrix-World’s first portable laser mosquito zapper
Probably you tightened them onto fresh grease, and it goofed the torque. I overtighten mine a bit. Spin em a bit. Back to them off to just loose. Spin em. Then final torque.Have some highway miles upcoming for the utility trailer - nothing major but decided I need to check the tires and the bearings. I put new bearings in a few years ago - maybe 10 or 15 - I don't know. The axle has the EZ-lube but I've never used it - just repacked or replaced bearings as normal. After researching how it worked I decided this time I was going to use it. Got it up to the garage and jacked up one side and got ready to pump grease. Decided I should make sure everything was tight first - it wasn't. Noticeable play in the wheel.
My inner voice said fix it by pumping grease in it. My adult voice said you have to pull the hub idiot.
Outer bearing:
Off to the store for new bearings and a seal. Only finished one side today.
I'm going to smell like grease for at least a week now.
Do you think that's just from sitting (maybe used an average of 3 times a year) or maybe I didn't get the right torque on the nut last time. I'm not sure.
Warranty?Broke ****...
That looks like water got inside to me.Do you think that's just from sitting (maybe used an average of 3 times a year) or maybe I didn't get the right torque on the nut last time. I'm not sure.
I was thinking that as well but look at this actual gouge on the race:That looks like water got inside to me.
Not on that one. Was a "SWT Tools" whoever they were. Pretty sure it was an old Taiwan import from way back in the day.Warranty?
Nah, we just used to get the boat up on a plane and pull the transom scupper plug. Drained all the water right out. Just remember to replace the plug before coming off the plane.Ya'll got auto bilge pumps on ya'lls boat?!?!
That's water/moisture in the bearing, could be from condensation in the cold.I was thinking that as well but look at this actual gouge on the race:
Hard to get a good pic but that horizontal line slightly below my finger at the top is not discoloration - it's cut into the race.
Should have the water intrusion taken care of now - I packed the bearings manually but used the EZ-lube to pump grease in until it started coming out the front. Should be sealed in there good now.
I’m not there yet, but it will be last resort. The boat is a 2005 bass tracker tourney 18ft, and in overall great shape. But a leak developed and it’s been ongoing for 7 years from my understanding. Being it’s an aluminum boat I’m going to focus on the seams and use dye to see if it finds the leak for me. Just need to take it to the lake once my snorkel set and dye kit comes in the mail.Bed liner can do wonders to hull leaks.
Oh we’ve done that because we forgot the plug, was able to drop someone at the dock while we ran around waiting for him to get the plug from the truck. He set it on the tailgate when he got distracted.Nah, we just used to get the boat up on a plane and pull the transom scupper plug. Drained all the water right out. Just remember to replace the plug before coming off the plane.
I got a spare pump in a storage compartment on the boat. If **** hit the fan I can drop this pump in the cavity and set the hose over the rail. Then just connect directly to the battery.The pump is not actually automatic. It is a standard Rule 2000 wired through a float switch that works like the float in your toilet bowl but comes on when the level is high and off when low enough. This pump operates only from the float, I have another smaller one that operates from a switch at the helm. Having 2 or more pumps is very common here. Sinking *****.
The famous American literary figure, Patrick McManus, had the right answer to that common problem: Make the scupper about a foot in diameter. You'll never even get the boat off the trailer before you realize you forgot the plug!Oh we’ve done that because we forgot the plug, was able to drop someone at the dock while we ran around waiting for him to get the plug from the truck. He set it on the tailgate when he got distracted.![]()
I know, not 'Murican, but we also had the ultimate in back-up bilge pumps: A hand-powered pump and a bilge bucket.I got a spare pump in a storage compartment on the boat. If **** hit the fan I can drop this pump in the cavity and set the hose over the rail. Then just connect directly to the battery.
Oh dang I’ve never heard anyone else mention that name before. Fine and Pleasant Misery was the first of his books I acquired and was one of my favourite books growing up.The famous American literary figure, Patrick McManus, had the right answer to that common problem: Make the scupper about a foot in diameter. You'll never even get the boat off the trailer before you realize you forgot the plug!
OuchCracked my Wilton C2.
I feel for you, I put weld in sub frame connectors in my car on Jackstands awhile back, that was painful
I was wondering about this approach as a few others I've spoken with have said this same thing, but I don't have a shop crane or engine stand to hold it while we do the work. If bought from Harbor Freight, it would be ~$500 for the required tools, and then storing them afterwards (not a major issue since I'm sure they'd be useful again) but having the engine out would be a major help.Usually faster to just pull the engine and leave the trans in.
but the bearings themselves showed no sign of wear or staining. They looked just fine but since I had the hub off and had a new set of bearings on the bench they got replaced.
