Filter funnel
Sumboodie
AK
Trying to source a funnel that can hold 3-4 quarts and has a decent screen... maybe 100 mesh or so.
Needs to be able to flow oil, like gear oil, hydraulic, etc.
I've found small ones and used paint filters. They only hold a cup or two.
The oil I have to "filter" is in gallon jugs so would be way less tedious to be able to dump the whole thing, or at least most of it.
signcrafter
rlitman
Long Island
I've seen funnels with garden hose connections. You could screw that into a real filter.
I'd try a disc filter before a screen if I were filtering high volumes of oil (many gallons, not simply quarts). Disc filter packs remove particles in 3D, so they have a whole lot more surface area, which means more time before clogging.
I've owned a few of the flotool red giant funnels. Every one came with a circular screen taped to the side that I quickly tossed. It would probably be good for your purposes, but I use these as a sink basin for hand washing outside, and the screen slows it down too much.
Hohn
Diesel Central, Indiana
I have one like that, has no filter.
One like that or that one? They do have a screen and mine came with a screen. Even says it has a screen on oreilly's website, https://www.oreillyauto.com/detail/c/flotool/hopkins-flotool-red-plastic-funnel/hop5/10705. Pictures on the site show the screen taped to the side that you pop in the bottom of funnel.
I'll go away now.
I have that funnel. It comes with a screen taped to the side. Yes, it's easily lost, doesn't stay in and is borderline useless.
GeoBruin
Sumboodie
AK
The screen isn't that fine though, at least not the one I have.
rlitman
Long Island
Yeah, I don't think it's anywhere near 100 mesh, but I've always thrown mine out because it *****. Looking at a picture of a new one, my guess is its somewhere under 40, so good to keep crush washers and drain plugs out of a drum, but not much filtration.
Sumboodie
AK
Wondering what the micron is on a paint filter sock. Can't find anything.
It's drum bottoms, so 2-3 qts out of drums. I get 5-6 gallons a month.
WWheeler
Middleofnowhere USA
Try searching on "FloTool Red Giant QuickFill Funnel"
This is what we use at work..
I don't know where you can get it in quantities of just one.
rlitman
Long Island
...I don't know where you can get it in quantities of just one.
I have one of those too. Picked it up at a car parts store 20+ years ago. The brass screen was cast into the plastic, but it flowed so slow for me (with gasoline), that I punched it out.
