I'd put it at the top, but make sure to leave that landing outside of the door.Yea, I probably need to be think about separating the attic from the main space too. Not sure if I'd put a door at the top or the bottom. My instinct would be at the top.
Anyway, here are a few pics of the opening as it currently sits:
Lucky dog.Happy to report that five months and one winter later, the slab has cracked exactly where it was supposed to in the control joints. No cracks that I can see in the field.
Love the idea! I'm going to have to copy that. My builder cut the bottom of mine at an angle and it lets rodents/mice in. I assume they did that to prevent rot but i'm gonna rip it off and copy what you did.Getting ready to install garage doors and man doors. Got cute with the details and added a little PVC foot to the bottom of all the PT jambs.
A garage door company (Overhead Door Co.) wanted $27K for the three doors installed! I nearly fell over when I saw the quote.And you're spot on about the garage doors, too. We had two 9x7s put in, and for the price.... I probably could have done it myself with a helper, and saved a decent amount.
Your door guy was awful proud of his work. My guy only wanted $300 over the least cost of the parts for both doors that I could find anywhere. I couldn't hand him the cash fast enough.A garage door company (Overhead Door Co.) wanted $27K for the three doors installed! I nearly fell over when I saw the quote.
I'm in to these insulated doors with upgraded springs for right around $10K. Another $1800 for three LiftMaster 98022 openers. I'll take the $15K+ in savings every day of the week.
Absolutely ! Both of them !!!I think it came out great. Very robust looking and feeling.
Seeing as you are not afraid of a little extra work, you could have used 1/2" hardwood dowels instead of screws. No plugs required !For the second staircase (from the mezzanine to attic), I went for a timber frame design. 4x12 Doug Fir boards for both the stringers and treads. Mortise and tenon but also glued and screwed. I'll probably go back and cover the screw heads with a little wood button plugs or something.
Looking clean. I prefer the natural look. Coatings and films might get slippery especially wet. Could always do a light sanding if it gets marked up and stained and coat it then?
What are you plans for the upstairs loft railing? Will it be made to be easily removable with pins or some kind of hinge system to fold down to accommodate larger storage items? Or if its a 'hang out' finished space, to carry up furniture or larger items. Your top landing area doesn't look the largest and might be a tight swing for big items and such plus clear a 3-4ft tall railing height.
Only if you hand carved the pegs !Yea, that would've been true timber frame!
PVC wood or you can make tins for it. I prefer the PVC wood.Window extension trims. I can't decide exactly how to trim out the windows while accounting for the 2" of rigid foam I want to install behind the siding.
- Window extension trims. I can't decide exactly how to trim out the windows while accounting for the 2" of rigid foam I want to install behind the siding.
