The chicks do dig itThe women are going to find him irresistible.
The drain plug is directly above the crossmember, with no way to catch the oil cleanly.
Fumoto valve ?For those that have not changed oil on one of these trucks have no idea... The 1976 and older with the FE engines are real fun to manage the oil runoff the crossmember!
CT
That's just rust preventionFor those that have not changed oil on one of these trucks have no idea... The 1976 and older with the FE engines are real fun to manage the oil runoff the crossmember!
CT
They were designed to have the offending cross member rust out of the way before the first oil change.For those that have not changed oil on one of these trucks have no idea... The 1976 and older with the FE engines are real fun to manage the oil runoff the crossmember!
CT
Fumoto valve ?
I've been using them on all my vehicles for years. With the hose attachment they're no-mess.I have looked at these. Cannot confirm if one will fit, yet. Plan to buy one in the name of science to test.
CT
Gonna have to get one.I've been using them on all my vehicles for years. With the hose attachment they're no-mess.
Thanks Snake.D1VE block is typical 70s casting. D1 is 1971 but could have been cast long after that. Typical low compression engine.
D3 heads are 70/80s until the EFI heads. Big chambers.
The D0VE head is popular due to smaller chamber for more compression (and rocker studs) but the ports are about the same as a D3. The D0/D3 exhaust port is small and benefits from any type of porting. A ported D3 can support over 500 hp.
In general Ford V8s, including the 460 is exhaust limited. Factory cam has +14 degrees duration over the intake. Most aftermarket cams are 'chevy' type grinds with little to no exhaust split. Any type of exhaust improvement will noticeably help, headers, bigger pipes, free flowing muffler.
May be in line to pick up a few.Ready to start dragging logs around...
Static compression ratio in the low 8s. Anything with D3 heads with larger chambers has lower compression ratio. So roughly 72/73. The early performance car engines had flat top pistons in addition to the D0 head. In 73 Ford went to retarded cam timing, then back to straight up in 87 with the EFI version. There are also pistons with different compression heights (pin location to crown) through the years.Thanks Snake.
Is it safe to assume 8.5:1 compression. I’m not sure of the date they changed from the higher ratio.
I’d also like to know when they started retarding the timing chain.
I’ve heard the actual manufacturer date is under the intake manifold (I question the logic here) but I haven’t pulled it yet to find out.
Looks like you have a long term oil leak(s). The inside of the transmission housing is full of oil and debris, as is the rear of the block, and the oil pan gasket looks about ready to pop out.Any of you 460 guys can feel free to fill me in on anything interesting regarding these ancient beast - would be appreciated.
I’m going to work up a job hazard analysis for pulling the ******🫣
Thanks for your reply. Helpful.Looks like you have a long term oil leak(s). The inside of the transmission housing is full of oil and debris, as is the rear of the block, and the oil pan gasket looks about ready to pop out.
There is a 1 piece rubber oil pan gasket available with the larger holes for the timing cover bolts. Difficult, at best, to pull the pan with the engine in place, even raised.
An Edelbrock water pump will make a significant difference.
Hopefully that truck came with a 460, because if someone swapped passenger car exhaust manifolds and clearanced the frame on the passenger side, the frame will crack.
Just about the only header that will clear without major work are Hedman 89140 and the coated or heavy duty variants. Can be slipped in from underneath (vehicle on jackstands) without moving the engine.
I'd call these folks for a cam and timing set:
Custom Ford Camshafts | Cam Research Corp
Discover Custom Ford Camshafts by Cam Research Corp. Expertly tailored for Fords, experience unmatched power.www.camresearchcorp.com
And of course, there are those Edelbrock aluminum heads.
Ha.rear seal
Ha.
Gotta pull the engine, pan and crank.
You'll never get the top half of the rope seal out.
Kaase makes a one piece seal retrofit. It doesn't leak.
My skilsaw only has three.Good thing is that truck has maybe 20 wires in the whole harness.![]()
Changing spark plugs.Why is the engine coming out?
Yes.Impressive, but will Ai know what's bothering my wife?
