YoshiMoshi3
- Joined
- Nov 2, 2022
- Messages
- 508
Hi, I'm trying to figure out what torque wrench I need for my Honda Odyssey. The procedure says to tighten to 48 ft lb then an additional 60 degrees. So I need a 1/2 " drive torque wrench I presume. But how do I convert 48 ft lbs + 60 degrees, to a final torque value?
48 ft lb + 60 degrees = X ft lb?
What is X?
I see some digital torque wrenches that go up to 100 ft lb, some go to 250 ft lb, some go to 300 ft lb.
Seems like I need to figure out what X is, and then pick out a torque wrench.
Understood that I will follow the procedure and do 48 ft lb, and then additional 60 degrees, but how do I know if the torque wrench can handle doing that? The ranges specified for torque wrenches is in ft lbs, and not ft lbs plus some angle.
Thanks for any help!
What is X?
