A 350 ft-lb digital torque wrench without angle is completely useless. What's the purpose of the digital version if all it does is show the torque setting digitally? Craftsman had this **** 30 years ago and it was a bad idea then. Chris has had many great ideas but this doesn't seem to be one of them. The ad doesn't even mention if the units can be changed from ft-lb's to N-m which is what 80% of the specifications for modern machines use. The 91350 seems OK to me but the digital version I feel is a non-starter.
It does have N-m and other units.
It vibrates and progresses light colors to signal torque. You don't have to watch it.
You're correct that the 1st 1/2" anyone's made that can do a range up to 350 ft-lbs doesn't offer angle features, the goal was for someone who sometimes needs values in the 270's, 300's, 320's to not have to buy and store both a new 3/4" torque wrench and now 3/4" sockets too, using their existing 1/2" instead on those applications and lug nuts with the same tool.
It will be well priced, similar to many standard 250 ft-lb wrenches, while allowing for rechargeable use with 18650's too. If we priced this into or well into the $200's or something we would have failed at our motivation to make it.
We're not an Asian manufacturer adding tooth count to a USA made wrench and calling it the next best thing - not sure how that came up here as well, these were made to my drawings and materials requirements because of actual requests, for the above reasons. If you don't find yourself considering whether you need to pick up a 3/4" torque wrench and sockets you're likely not the target customer, but luckily no one is asking anyone to turn in their current useful torque wrenches - there won't be a marketing campaign implying you NEED these.
