Dedicated lug nut socket set
quilty
What's everybody using for a dedicated lug nut socket set? I'm considering this 5pc. Snappy set
PN#
  • 305LSDM
1Bad55Chevy
Milwaukee.
I have been using that kit for about 8 months with no issues. I have only ran across a few aftermarket wheels where they wouldn't fit.
My biggest issue is swollen lugs on dodge trucks. I typically find myself grabbing a 23mm impact for those.
AJHD
I still have a few of Snap On sockets meant for lug nuts (19mm, 21mm, 22mm) I bought them many years ago, warrantied them each at least once.
I've had various flip sockets and other dedicated sockets over the years. I picked up the Koken set with the protective sleeves awhile back.
I don't think the Snap On are worth the money overall. Plenty of cheaper options.
That said, I know 17mm is Euro, but what the heck uses 18mm?
ecotec
I have the HF protective sockets and some Grey Pneumatic flip sockets with half sizes
Phang
Singapore
Steve_P
I have a 20? year old three piece set from HF with plastic sleeves- they're fine. I upgraded the 21mm to the Koken shown above with the built in extension, because that's what I use 95% of the time, and I guess I wanted to be fancy; it's also ready for the torque wrench and I don't need an extension. I also have a 21/21.5 CTA? flip socket without the plastic sleeve for those swollen nuts.
L.Cheapo
I have the Hazet 3pc set. Tossed them in the cardboard box of misfit tools immediately, likely never to be used again unless I need a sacrificial tool.
They are broached shallow to the point they damaged the lug nuts on a new vehicle. I suppose that depends on the lugs though.
I replaced them with the Ko-Ken and no longer have issues.
nh_yota
Seacoast New Hampshire
I have 19mm and 21mm deep Channellock sockets from the hardware store. I keep them in a Klein canvas zipper bag in my truck along with my other "random" or individual sockets or adapters I've purchased to work on the truck over the years. This way I don't lose the 19mm and 21mm from my big set in the garage and they're also in the truck with me if I need them on the road.
Jeepster04
Craftsman that I bought from Sears back in the day.
I dont much like them. They are so thick that they will sometimes rub on the rim. I'll just use a chrome socket when that happens, but I never use an impact on lug nuts... Only a breaker bar and a torque wrench.
Phang
Singapore
there are plastic insert (17, 19mm are flat, 21mm is dish shape) in the sockets to control the engagement depth, I have no idea why Hazet do that to the sockets
for 17mm socket, the depth is 14.20mm, 17mm depth for the 19mm socket
I don't have problem with my car's wheel bolt (pic below) but I can see it doesn't allow full engagement on wheel lug/nut with taller head
Dave455
Sussex, England
I think the first thing to decide is what you want.
The Snap On are impact sockets, with a deeper broach, which is nice, but that’s an expensive set. Do you need the deeper broach? Do you need an 18mm? I’ve never needed one. Would two or three individual sockets be better?
The KoKen are a lot more tool. They are extended sockets rather than deep, and are very thin walled. Nice if you need them, but you might not.
I also have to mention price. That “set” in it‘s Nanuk case is $320.
A set of three sockets, in the U.K, currently costs the equivalent of $95, and that INCLUDES British sales tax. So you are paying $225 for the 22mm socket and the case. Seems a lot. I know there are tariffs at the mo, but even so...
Personally, I would just go out and buy some generic impact sockets, in the sizes you need, and a short extension. Job done. If you need thin walled, then get thin walled. If you prefer a deep socket, get those.
Either way, any impact sockets are essentially a consumable item, so you want to be able to get spares of the sizes you use most. For me a “set” would comprise 11/16, 3/4, and about three 17mm’s! Everybody’s needs are different though.
Snapped-off
Indiana
I've got a flip socket set, but I'm not sure I've ever used it.
I also have a Sunex 17mm and 19mm sleeved sockets for the fancy Euros, and everything else just gets a regular old impact.
willf650
Holy ****.
I use the harbor freight set that had nylon covers.
Same here. I only change/rotate tires 2-3 times a year at best and only bought them because my regular impact sockets wouldn’t fit in the lug nut opening in wheel.
pbon
If $200 is burning a hole in your pocket, the Snap-on look nice. I have $200, but it is not burning a hole in my pocket. Don’t have any Snap-on. Don’t need it. If I was a professional mechanic, I might buy it. I have some no name plastic covered lug nut sockets.
308guru
I don't have them, but I like the longer length of the Koken's. Eliminates the need for a short extension, which I often find myself using on wheels with my current Milwaukee lug sockets.
L.Cheapo
Looks like the price has gone up a lot. It can be had today for $250 or so. Much less if you don't want the case. I think it was ~$20 more for the case when I bought it so why not? :ROFLMAO:
Here's the invoice:
Honestly, I like them enough that I'd buy them again as a 3 piece set plus the 22mm from Zoro with a 20% off coupon for $110 if I needed them. I'm a Snappy kinda guy, but I prefer my Ko-Ken lug sockets to my lone Snappy 19mm lug socket. No wheel finish damage if you "miss" with the Ko-Kens.
rust in the eye
Chicagoland
A lot of do-re-mi for 5 impact sockets.
Do you use an impact on lug nuts?
Snappy is saying the deeper broach will lessen the likelyhood of damaging lug nut covers. NOT impacting them lessens the likelyhood even more.
Speaking of deeper broach my cheap impact sockets from across the Pacific are also deep broached.
wantedabiggergarage
Member Emeritus
Independence, MO, USA.
I believe it was two sets of the impact flip sockets (some of them are still in the move stuff, before the cancer diagnosis). I don't remember what brand as I had bought three, Astro, Craftsman, and Snap on. (one was a backup for the shop, as at the time someone wondered off with the shops in pocket)
Then I bought the Astro sleeved set, decades ago at a damaged freight store for $10. I left them with the shop as I didn't have expensive rims, occasionally the shop did.
Monday, I bought the red HF set, because I wanted them again for the future (hope to beat, plan on not). Gives me something to look forward to.
Wrench97
Southeastern Pa
PN#
  • 305LSDM
Snap On impact sockets are soft and wear, easier on the anvils but if you don't see a tool truck all the time warranty should taken into condersidation. Tekton, Astro, Grey Pneumatic, HF may be better choices.
AJHD
That is one of the dumbest things I have ever seen. I don't understand what purpose that is supposed to serve besides increasing the price. The plastic looks to be removable at least.
I was actually looking at these Hazet sockets, but that design decision removes it from any future consideration. Glad I bought the Koken set instead.
Phang
Singapore
yes, those plastic insert seems removable
my other set is KTC, it has a hard rubber pad inside to prevent scratching those shiny dome head
but they don't have the plastic sleeve to prevent scratching the wheels
looks like ko-ken is the better set
3mm more than the Hazet
Chipm
Georgia
I don't understand what purpose that is supposed to serve...
Some lug nuts can sit so far down in the socket that you cannot start them on the wheel stud because the stud is not long enough to reach the lug nut that is recessed way down in the socket. The plastic insert prevents this problem by pushing the nut out to the socket face.
Rusted Nut
Northern Arizona
Conversely, some lug studs stick out; and these sockets won’t reach the nut.
Fedwrench
Valley of the sun
For nice wheels I use the colored coded Ko-Ken set with the built in extension pictured above. For steel wheels/older wheels, old SK USA 19/21/22 mm.
for those nasty *** Ford multipiece **** lug nuts that get malformed/swollen, the Astro half sized impact sockets make life easier:
xjfish
I've never had a dedicated set that I only use. Mainly a mixed bag of Matco ADV (Sunex), MAC, and Snap-On regular deep impact sockets if room around lug nut. Otherwise, have low-profile Matco flip sockets, they get used a lot, and do crack occasionally. Also have the half-sized set for pregnant lug nuts...
Ilikeike
Northern Ca.
At home I really only use one for my wheel locks.
So I made my own custom tool
I welded a socket to the socket key, and dipped it in that rubber stuff you use for tool handles.
It's just the right length so I don't need extension.
I have some cheap ones too , but the sleeve cracked and chipped off the one that I used.
Get what you pay for I guess.
moemc
I like these and almost ordered them but I can tell they won’t be deep enough for race cars with extended wheel studs unless they also have extended deep lug nuts. These would be perfect for OEM style lugs though. I have deeper Koken lug sockets without the built in extension that are deep enough for my extended studs.
