I'm insulating the roof of my new-construction garage (climate zone 5A - Boston). I have attic trusses comprising the roof structure. The roof is unvented and sealed up nice and tight, intended to be part of the conditioned space. (I built a vented over-roof that includes R20 exterior rigid foam.)
Anyway, I'm currently installing R30 batts on the underside of the roof deck. The question is, can I just get it above the attic room and then run it over the ceiling, or should I go to the effort of running the insulation from the eave all the way to the ridge? Running it over the attic ceiling would leave a small less-insulated space between the top of the room and the ridge. I say less-insulated because I still have R20 worth of rigid foam on top of the roof.
I guess I'd rather install the insulation right over the attic ceiling since that would use a bit less insulation and be less labor, but not if it has a negative effect on building performance in some way I'm not thinking of.
See the two attached drawings. Blue line indicates exterior rigid foam. Red line indicates potential batt insulation placement.
