The VISES of Garage Journal
1982fxr
Phoenix
Has anybody seen the new Wilton Apprentice series vises? They have the bullet design. Cost is only $150 for the 6”.
Obviously most here have/want USA made classic vises, but I could see this being an inexpensive way to get into a good looking, probably decent quality vise with a lifetime warranty. IMG_2326.png
That's cheaper than harbor freight
jopy
Australia
Update on my vise project
I just got a 3D scan taken of the base vise so I can start getting quotes from foundries
Also I just ordered the materials for the screw and the handle and the final weight of the screw will be approximately 50KG!!
fishwatcher
Yes, you’re right. The 6” Doyle is $199 vs the Wilton 6” for $149. The Doyle 4” from HF is the same price as the 4” Wilton Apprentice at just under $100. Both have lifetime warranties.
I’m interested in seeing the first reviews of these new Apprentice vises. I still like and hugely prefer my USA made vintage Wilton’s of course. It’s very interesting that the look (and some of the function) of the iconic Wilton Bullet is now available at such a low price point.
dannyr
Sheffield England
dutch: One quick quibble - if you found that vice at a "car boot sale" then what you found is an Entwisle and Kenyon's vice.
The patent for the vice/vise was awarded to Wilson Riley
Mr. Riley's vices were on exhibit in 1879
Notice that Exhibit 7367 is a No.2 with 6" jaws and Instantaneous Grip
good information
small aside - the patent shows the 'handle' for the engineers version with a 'doorknob' end - like the joiner's vise - this was a cast iron part and today often has the end missing -- when it came to manufacture of the engineers version they must have already realised this weakness and made the handle of a slightly different shape - see dutch's fine example - and of wrought iron, malleable iron or steel
dutchgray
Dorset. England.
good information
I will have a better look to see if I can tell if that handle was cast or forged not that is easy to do, it's definitely been machined at the hand grip area, it has a center dimple in from where it would have been on a lathe.
CRSINMICH
Southeastern Michigan
dutch and danny: This is a cut from a 1914 Crerar, Adams & Co. Catalog of Railway Supplies in Chicago. The handle looks like a cross between the patent drawing and dutch's vice. It looks like it could have been turned on a lathe, however, drawings in catalogs and patents are not entirely reliable.
Notice that none of the vises listed have 6" jaws. A No.15 would have been just about that size. Does that mean that by 1914 Massey no longer offered 6" versions? All that could be said for certain is that Crerar, Adams didn't offer a 6" vise.
Mr. Wonderful
Reed 204R static jaw....is the area under the jaw normally like this? Forge welded? Repaired? This is my 1st Reed so I am not familiar with their specifics. Thanks20250817_101959.jpg20250816_164708.jpg
Both my 104R and 204R have a similar chipping under the jaws. I'll take some pictures when I get a chance. I don't think that's a repair.
wtn1271
attached
Here's a picture of a Craftsman Reed from 1943. It looks similar to mine. I am thinking it is this way from the factory or the same guy repaired both.
akasrick
south jersey
Hollow towers? They jaws had to be attached someway. There is at least one patent showing a new way of attaching, fairly involved, I wouldn't imagine it got much traction.
Looks like the towers were at least beefed up.
Akasrick
wtn1271
attached
Chef Rex,
Yours looks similar too, especially the outlined areas. Some vises probably just have a better casting. Screenshot_20250818_113833_Chrome.jpg
akasrick
south jersey
There was also a process which I have no idea if Reed used, for what I call Electro Magically welded. Which means I have no idea how it was accomplished. I imagine a lot of energy was used. Looking at mine looks like it has none of the smoothness yours has.
akasrick
KMScott
Sure would like to see how they fit the hard jaws in the mold when the vise is casted. All of my Reeds had cast in jaws just like these examples you guys have shown.
I have replaced several of these cast in jaws and every time I break thru the 60 R/C I look for Copper or Nickel often used in brazing hard inserts to softer cast material. I found what looks like Copper in the 106 jaws I replaced. The Reed inserts on the R series have the round boss in the center of the jaw inserts. I’m assuming for more surface area in the casting.
How did they cast the Static and Dynamic with the finished hardened serrated jaws and then how well they align up to each other.
682bear
West GA
Well... now I guess I'll have to look at my Reedsman and see what it looks like under the jaws...
-Bear
TheRealZeus
CONTINENTAL USA
“Insert Casting.” the preform harden steel jaws would be referred to as “cast-in inserts,” as a generic term to the technique. They are placed in the molds prior to pouring.
I have a simple theory that somebody gettin’ in the business went to the parker foundry, saw men machining the jaws with hand files by eye 👁️ fitting them flush, and said… “heck naw.. 😮 we’ll just pour it onto the jaws.”
colmal
Australia
^^ You are welcome. Let me know if you find numbers or lettering when you clean it - especially if it is NOT a G-P.
No ID on it-original black paint with a darker red on jaw area- 2" 3lb 8.5 oz
Most of the red came off as I left it a bit longer in the molasses being fully seized up, came out well thou, even the retaining screw was removed with no effort, threads are excellent, lightly used, the locating pins look to have been agriculturally filed on there ends, can't imagine that's original, probably just leave it as it is, won't repaint it.SAM_4867.JPGSAM_4880.JPG
Dawn, G-P (?), Stanley, 2 inchers.
fullthrottle24
Do you have a date on that adv. Time and vise improvements march on.
akasrick
Not that particular catalog, but another one I have is dated 1949 with a flat nose Reed with same description.
While time does indeed march on, the improvements, durability, quality of materials and craftsmanship of skilled machinists is unfortunately gone.
KMScott
Still a few skilled Toolmakers around, not gone yet. Just wish I had a few apprentice that I could have trained.
I would love to give the new Machinist a drawing from when I was new in this trade Like this Starrett 326 Pipe jaw drawing and turn them loose. Finished these up earlier this week.
fullthrottle24
You are correct, I appreciate your skills and knowledge you share here with us. I was specifically referring to the corporate world’s planned obsolescence and people not appreciating the value of quality built to last and service products that last for generations. My grandfather was a tool and die maker, his vise sits on my bench as tribute to his craft.
micahd1997
Immaculate, Kevin. I know of at least two brothers that (both skilled machinists) that you passed alot of your wisdom on to.
micahd1997
Here’s a recent find for me - a 2.5”, 12lb Monarch № 210. It may be the closest that I ever come to finding a new old stock Prentiss. Virtually 100% of the original japanning finish is still intact. The jaw serrations are crisp, and except for signs of very light use on the tops of the jaw towers, it is practically unused. It came from the shop of a 97 year old New York native. Sadly his health is in steep decline, so my only communication was with his son. However, given the vise’s condition I wouldn’t be surprised to hear that he was its only owner.
Prentiss’ entire line of Monarch vises was discontinued in February 1919, so it’s at least 106 years old. Pretty incredible that vises like this exist, and I know many of them are held by members in this thread
The listing was taken down, but I just saw a Colombian 109 sell near me, didn't see it on the list of vices and can't find any information online, anyone know anything about it?
micahd1997
Any pictures? Did you actually see the "9" in the "109"? Because I don't believe Columbian ever made a 109
Unfortunately by the time I thought of screenshotting them it had been removed and the lady didn't send me more photos.. It really looked like a 109, but I guess it could have been a ground off 8? It was covered in outside grime and half eaten by bushes.
Tom Graham
Oklahoma
When you’re restoring an entire family of Charles Parker 97x series vises, you know those jaw inserts are going to need some attention. So, you reach out to Logan Kendrick (AntiqueVises.com) knowing that he’ll do an excellent and fast job re-surfacing them. I am delighted with the job he did!
