Undersink Outlet - Switched
ssjones
Covington, Louisiana
I have a curious electric outlet issue that I just discovered.
Our home in Louisiana, purchased last year, has a pretty elaborate 7-stage under sink water filtration system with a UV lamp. The water down here is awful, so I like having this for drinking water, etc.
I purchased a new set of the three filters and a UV lamp.
When I put the UV light in, it didn't come on.
The light goes to a duplex outlet under the sink, which is where the garbage disposal also gets power.
The outlet is switched. So, the UV light never worked, unless the garbage disposal was on (and likely the bulb was near new)
My issue is they didn't run power to the outlet, and then to a wall switch. But rather power the wall switch, than to the outlet.
I don't think there is an easy solution. Pulling a new wire under there would be pretty challenging.
Are there any other options?
PCustoms
VT
Leave the switch on (or nut the wires together and put a blank cover on) now you have power at the outlet. Come off that with a second switch to a new outlet for the disposal.
You could have an air switch as the "new" switch too.
csp
Franktown, CO
Are you sure that both plugs of the outlets are switched? Those undercabinet outlets usually also are the power source for a dishwasher which requires a constant hot. This is done by breaking the buss bar on the hot side of the outlet and running each plug on it's own power leg in the same wire, usually 12-3 with a black/red/white/ground arrangement.
ssjones
Yep, tried that.
The outlet only as a white/black to one leg of the duplex from the switch. When I broke the bus bar on the lower outlet, now it no longer works with the switch.
ssjones
Codyboy
S.E. TEXAS
We just leave the switch on for the dishwasher.
It doesn't make the dw turn on but just supplies power to it.
I think the only reason there's a switch is to keep toddlers from ousing buttons on the dw and turning it on.
Shiftless
East Bay SFO
We're getting new countertops in the near future, that will be the time to install that switch.
I installed my garbage disposer air switch into one of the holes that was already there in my kitchen sink next to the faucet.
Maybe your sink has extra holes. Many do depending on what kind of faucet was installed.
75gmck25
Alexandria, VA
Air-operated garbage disposal switches have been common in kitchens for quite a while. Adding a hole for switch installation should be a common task for a countertop designer/builder.
ssjones
I guess I'll have to wait until the new countertops go on. When removed,I'll have access to run correct wiring to the outlet, then back to the switch (mine is reversed). I'll just eliminate the wall switch and go with the air switch.
PCustoms
VT
As I said in post 3, nut the wires together in the switch box and use a blank cover. Now the outlet is always hot.
Plug an air switch into the existing outlet, and drill a hole in the countertop.
Done, and can be transferred to the new countertop in a minute.
dave*99
Coastal NJ
Is it possible you have the wiring arrangement mentioned in post 4? With your dishwasher plugged into the switched receptacle rather than the always live receptacle?
theoldwizard1
SE MI
When garbage disposers first started showing up, it was common to have the switch UNDER the sink !
ssjones
As I said in post 3, but the wires together in the switch box and use a blank cover. Not the outlet is always hot.
Ah, thanks, that sunk in now. Just eliminate the switch, understood!
We have an in-counter soap dispenser that is always empty. I'll see if I can talk the wife into repurposing that hole.
Codyboy
S.E. TEXAS
No not possible.
My dishwasher has its own switch, the garbage disposal has its own switch.
Each is hardwired from their switch.
I do not have an outlet under any cabinets.
Hardwired. No cords.
Like God intended .
no704
Bypass switch. Split outlet, add switch under sink for disposal.
LOW1
ontario
Since the dishwasher is hardwired can you add a box and outlet behind the dw For the light?
