signcrafter
- Joined
- May 9, 2012
- Messages
- 12,498
Wow, guess I kind of forgot about this thread and just been too busy to post updates. Still chugging away with all sorts of stuff and still trying to set up the new shop. Still going back and forth between two states. Had a few big projects come up so the move and work on house to sell got paused for those. Been working on it when I can.
Keep trying to organize and arrange the shop to fit everything I need in it and also keep it usable. It's a really challenge and I do what I can as some extra funds are available. Been spending a lot of time on Facebook marketplace searching for deals on shop stuff I need or want.
A couple projects in got done in the last week are the tire changing area. It's in the back of the "storage" side of the shop. Not ideal to walk each tire down and aisle to get to the changer but it seems like the best option to maximize my layout for storage. I pretty much only do tires for myself and then tpms sensors and a few plug/patches for others. So shouldn't be a big deal for how little I use them and should work now. Will see after shop is all set up how things work out and if I need to move things around or not. Also mounted the branick strut spring compressor I picked up off marketplace for a good deal a couple weeks ago. Had no idea what height to mount it at so that may have to get changed.
The two stainless shelves I got from a restaurant remodel I did, they were microwave shelves. The one restaurant I did had 11 microwaves when we started from the old owners. Crazy that is how some restaurants operate. We ripped them all out besides 2 so I kept some of the shelves and they work good for the shop. I will be taking them down though. I'm going to put a sheet of plywood screwed to the black shelving and have been keeping my eye out for a used wall cabinet to hold all the valve stems and other tire stuff.
I also will be taking that sliding door out and closing that off. There is a 3 seasons type room out there that we won't be using for that, we are using it for yard stuff storage. Want to take out another sliding door on the other side of that room and put a roll up garage door and will use that as a shed for the riding mower and all the other yard equipment. But that is down the road. Once I close off the shop from that room I will put wall cabinets or other storage devices to hold wheel weights and stuff for the balancer. I will also add a tire rack above to store tires. I made one for the last shop out of unistrut and it works out good to store tires and rims or just hold old tires until I get a chance to dispose of them.
Also in this corner is a tire repair stand to spread the tire and hold it while you prep and install a plug/patch. And a tire tool stand. It has spots for all kinds of tools and then air hook up for two impact guns. Think they are made for tire shops to be mounted between two bays so techs can work on a car on each side at the same time. Haven't decided where I want to put it but I will use it to hold tire tools and also my low speed die grinder to do tire plug patches. It has two air hook ups that I will put coil hoses on so I may put an impact on one. Don't really need an impact back there besides for struts. But I have a few 1/2" air impacts I rarely use since getting my M18 so might just leave one hooked up back there. Also need a blow gun back there. Can either do a hose reel with blow gun on it and tire buffer and impact on tool stand, or tire buffer and blow gun on tool stand and then have impact hooked up right at spring compressor. Lots of decisions laying this stuff out. Too many decisions. Lol.
Can kind of see the grey shelves I started setting up. Going to have a bunch of rows of shelving from this back area to the front of garage. This is what I call Scott's hardware store. Being a contractor and working on vehicles I have a pretty good hardware department. Most of it is screws and nails for jobs but there is lots of nuts and bolts and then all the other stuff like fittings, orings, brake line fittings and bleeders, etc. This half of the 4 car garage will be just storage for the most part.
On the tire machine is my harbor freight small tire changer. I really like this thing for mower and ATV tires. I drilled a scrap rotor and mounted it to that. The can close the rim clamp on the rotor to hold it in place while changing those smaller tires. Works great.
I'm also thinking about moving the safety kleen parts washer back by the balancer. Right now it's in the working half of the garage and trying to decide if I want to keep it there or move it back out of the way. If I move it I can put something else where it is now. A few weeks back I came across a transmission tear down table for 80 bucks on marketplace. I've never rebuilt a transmission but I've wanted one of these tables for a while to do messy work on and it collect the fluid in the drain. This one is really heavy duty and would be nice as a workbench in the main working area of the shop. So thinking about moving parts washer back by tire machines and tear down table work bench to where the parts washer is now.
