Tools of Japan
Andres26tnt
It's an klein design bit holder, they just went to a Japanese manufacturer, probably Anex. Why Anex? Because vessel has a larger footprint in the USA so they are competitors in that space. Also the design looks more a Anex ball screwdriver then the vessel.
tamaraw
Found a stainless 9mm Olfa (SVR-2) at the bookstore earlier, some comparison pictures next to a classic 2B model.
Dimensions are smaller but it feels blockier in the hand because of the shape. Blade is marked stainless as well, so I guess the only moisture vulnerable part would be the yellow sticker. The detents are smaller and weaker, but theoretically give you more options for blade depth per blade segment.
The side clips are kind of a silly design element imho because they pull out with minimal effort but at least the stainless one can be bent to increase the holding tension. Still don't think I would trust it much.
USDM packaging style on the left, JDM packaging style on the right
GeoBruin
Just got another Hory RC-101 "Caddy".
This one is in better shape than my last one. No missing parts and it had the rubber molding on all three levels. I had also never seen this color before. I've only seen them in red and yellow. This one is a true Hazet Assistant pretender.
LWB
ON, Canada
Someone stole my caddy! Nice colour. This was red and I did it in Tremclad french blue.
rick carpenter
Huntsville, East Texas
I carried my SVR-2 daily before I retired. I never had trouble with the knife with moisture other than the East Texas humidity making it a tad slippery sometimes. I tried carbon blades but they rusted right away so back to ss. The clip looked enough like a pen or a marker in my shirt pockets that no one at the school questioned it. It was a legit carry tho, I needed it quite frequently in the warehouse & in the library and maintenance/custodial workers carried always their knives. I emailed Olfa and suggested they make the clip look exactly like a pen for office carry situations.
Now that I'm doing contract work in the warehouse I carry an XA-1 for a handy 9mm with a more substantial non-slip handle than the SVR-2. I haven't ever fondled a 2B... looks interesting.
Andres26tnt
Finally bought the Vessel precision bit set 9836 everyone is raving about. It's a great kit, but has one problem I didn't like. The driver is all metal which is fine, but has no knurling or area where to grab when screws are to tight to remove. It's very slippery, Japan is very hot and humid so sweat and whatever makes it hard to turn. The neck does have flats, but they are slimmer then the rest of the driver. Kinda defeats the purpose of having them.
Not a huge issue as I bought it for another reason. That is to use it in conjunction with the Vessel ball grip electric screwdriver 220usb-s1. I picked this nice vessel used at hard-off for $14 in very good condition.
For those interested you will need a 4mm to 6.3mm precision bit adapter. That will give you the ability to use the small bits on a regular 1/4 bit driver.
pfbz
Been working on migrating my sockets over to the new Icon box, grouped all the Koken sockets together instead of strictly by drive size mixed in with other sockets...
Some Z-eal, Nut-grips, Surface drive in various drive size and depth... Plus some Koken spinners, adapters, etc.
Stridercondor
Milwaukee
I need one of these real bad. Where do you find these?
Steel_Rain
New Klein Tools “Made in Japan” driver:
The bit holder is really cool, it holds both styles of US and Japanese power bits, as well, as straight 1/4" shaft.
Do Vessel or Anex have any offerings with that kind of bit holder?
Back in stock (or at least "backorderable") on Amazon as of 26 August 2025 @ 0900 EST:
I got one coming:
I know it's a Klein tool product, but it is Made in Japan (y).
Andres26tnt
If you don't want to wait for that Klein I recommend the Anex 397-1. Excellent ratchet driver, will accept any type of bit holder as it's a friction fit. Of course you can't use small bits directly as they will get stuck, but I imagine no one is that dumb 😅. You can't do it on a Klein either, but with that one you can take it out easy.
Etchase
Hawaii
I can’t take the Anex apart yet, nor see that well into the hex, but my guess is the bits are held into the driver by a leaf spring on a single facet of the hex. It looks like bits up to 1 5/16 long will be lost in the driver forever, short of welding a retrieval tool to it or some other method. We all have drivers for short bits. If you absolutely needed to use a short bit, I tried a threaded hex spacer about 7/8 long into the driver which spaced the 1 inch bit far enough out to be removed. When it came time to remove the spacer, I screwed a bolt into the thread and removed the spacer by pulling on the bolt. A ridiculously complicated procedure. The locked position on the Anex ratcheting mechanism is very tight with basically no play. It’s a good tool.
Andres26tnt
I own one of these Anex ratcheting screwdrivers and I think it is clunky and not one of my favorites.
Weird, all these ball drivers are basically the same size and shape. I prefer the Anex 72t as the fitment of the blade is tight with minimal to no play. I hate wobbly bit drivers. Maybe the older 60t version with the switch at the bottom 🤔. That one had loose fitment(own one), not my favorite.
tamaraw
You could use something like PB 450.M or PB 451.M as an extension to hold short bits, I use that on my Anex 8100 handle.
Andres26tnt
Yep it's some sort of leaf spring with a round bump, very tight. Tried to take a picture but just cat get it to be clear.
For short bits I always use a nice magnetic bit holder. Preferably a slim one like this bahco or engineer dr-323
GeoBruin
Vessel has the 900ALWC which has the MEGADORA style grip and a locking mechanism that is very similar to the Wiha Centrofix. It holds all kinds of bits and locks up really well. The problem is they're really hard to find.
I really like the looks of this Klein.
Andres26tnt
That's because it's discontinued, no longer sold. Interesting enough you can get it all day long from China or the Philippines.
Reed Prince
Northern Virginia USA
There's been a lot of activity on this thread since I read it yesterday. I came to comment on the Klein driver, but much of what I was going to say has now been covered by other posts.
I think the YouTube video comparison to the Wiha CentroFix is apt. I have a Wiha, which I keep with my security hex and torx Wiha Power Blade sets. Wonderfully made, but as the video points out, not perfect. If I used this type of driver handle regularly, I would probably try out the Klein.
But what I want most often is a good ratcheting screwdriver. I've tried all I've encountered, from Chinese cheapos up to PB Swiss, and what I've settled on is the Anex 397. I like to start a screw by spinning the shaft with my thumb and forefinger while applying pressure with my palm, and the Anex does this well. The mechanism doesn't purr like the PBs, but those guys have no good place to spin the shaft. And I don't need multibit storage or want to use short bits. I often need ones that are long and slender. I keep a couple and the Anex in the small bag I take with me to every job.
I happened to notice this Anex driver today, which I would not recommend. I bought the stubby version years ago and quickly disposed of it. The mechanism is heavy, the rotation adjustment is inconveniently on the top of the handle, and there is almost nowhere to spin the shaft with your fingers. I imagine it's 60 teeth give it slightly less back drag. So I suppose it is perfect for something, somewhere.
rick carpenter
I just use a piece of 4.5mm diameter round stock when I need a spacer for my 397. I made sure that diameter slid freely before I cut it down and dropped it in the first time.
I agree with the folks who say the 397 is awesome.
If the 395 insertion depth is as shallow as its stubby cousin, like @Reed Prince said, it ***** (too). I have the stubby and just haven't tossed it yet. The fixed Anex handles and the 397, all with 40mm bit insertion depth, are superb.
kanai
Taiwan, almost all makita hand tools are made there or china. Heck the majority of makita powertool line is also made in china 😭.
Makes sense. Thank you. I'd love to pay more for a made-in-Japan set but I guess there are other Japanese manufacturers for that.
kanai
Is there a Japanese brand tool set (1/4 and 3/8 sockets, wrenches, drivers, etc.) that is well packaged? I know of the KTC sets but can't find one I like. And Tone has sets too, but nothing interesting there either.
Reed Prince
Factory Gear has some other options. I think their Deen COO is usually Taiwan, though. https://ec.f-gear.co.jp/category/HANDTOOL_SET/
Andres26tnt
What do you mean by well packaged? As in the trays they come with?
So most offer foam as an option in their boxes, those are the best IMO. The plastic trays they offer are flimsy and thin. I own the KTC screwdriver plastic tray, bought it for a box I was building. Was so flimsy it went to the trash right away 😂.
As for interesting 🤔, what are you looking for? All these sets are the same. So none will have super special tooling. I made my own to get around that.
glenng
I was watching bzeug's review on the Klein driver, and someone in the comments suggested Sunflag could be the OEM based on their 1236 driver. They say the chuck is similar and you can see the ribbing in handle design is similar too.
Sunflag 1236:
bzeug review:
Qualitytools
SOCAL
I also recommend the Anex, I have had it for a couple of years and Love it. I do not use it with short bits.
