I wonder who makes it for them? Around $16-17 is a great price.
I asked the same question a few posts up. Has to Annex or Vessel?
The ball bearing arrangement is like the Wiha Centrofix.Yeah it seems like Anex or Vessel since they do the ball grip, but it's the bit holder that throws me off. I haven't seen anything like that in any of their offerings.
Klein “Japan made” ball grip available right now on Amazon
Klein Tools 32960A Fastbit Tru-Grip Screwdriver, Ball-Style Handle with Quick-Release Collar, #2 Phillips and 6 mm Slotted Double-Ended Bit, 1/4-Inch Bit Compatible https://a.co/d/12ZLxxB
Just got another Hory RC-101 "Caddy".
This one is in better shape than my last one. No missing parts and it had the rubber molding on all three levels. I had also never seen this color before. I've only seen them in red and yellow. This one is a true Hazet Assistant pretender.
I carried my SVR-2 daily before I retired. I never had trouble with the knife with moisture other than the East Texas humidity making it a tad slippery sometimes. I tried carbon blades but they rusted right away so back to ss. The clip looked enough like a pen or a marker in my shirt pockets that no one at the school questioned it. It was a legit carry tho, I needed it quite frequently in the warehouse & in the library and maintenance/custodial workers carried always their knives. I emailed Olfa and suggested they make the clip look exactly like a pen for office carry situations.Found a stainless 9mm Olfa (SVR-2) at the bookstore earlier, some comparison pictures next to a classic 2B model.
Dimensions are smaller but it feels blockier in the hand because of the shape. Blade is marked stainless as well, so I guess the only moisture vulnerable part would be the yellow sticker. The detents are smaller and weaker, but theoretically give you more options for blade depth per blade segment.
The side clips are kind of a silly design element imho because they pull out with minimal effort but at least the stainless one can be bent to increase the holding tension. Still don't think I would trust it much.
USDM packaging style on the left, JDM packaging style on the right
I need one of these real bad. Where do you find these?Just got another Hory RC-101 "Caddy".
New Klein Tools “Made in Japan” driver:
Fastbit Tru-Grip Screwdriver, Phillips, Slotted Bits - 32960A | Klein Tools
The Klein Tools Fastbit Tru-Grip Screwdriver offers a round handle design to enable greater torque and comfort on all driving tasks. The fastbit collar on the handle quickly releases the double-ended bit, allowing you to flip between the #2 Phillips and the 6 mm Slotted-end quickly and easily...www.kleintools.com
The bit holder is really cool, it holds both styles of US and Japanese power bits, as well, as straight 1/4" shaft.
Do Vessel or Anex have any offerings with that kind of bit holder?
I own one of these Anex ratcheting screwdrivers and I think it is clunky and not one of my favorites.
You could use something like PB 450.M or PB 451.M as an extension to hold short bits, I use that on my Anex 8100 handle.I can’t take the Anex apart yet, nor see that well into the hex, but my guess is the bits are held into the driver by a leaf spring on a single facet of the hex. It looks like bits up to 1 5/16 long will be lost in the driver forever, short of welding a retrieval tool to it or some other method. We all have drivers for short bits. If you absolutely needed to use a short bit, I tried a threaded hex spacer about 7/8 long into the driver which spaced the 1 inch bit far enough out to be removed. When it came time to remove the spacer, I screwed a bolt into the thread and removed the spacer by pulling on the bolt. A ridiculously complicated procedure. The locked position on the Anex ratcheting mechanism is very tight with basically no play. It’s a good tool.
Klein Ball Grip vs Wiha CentroFix:The bit holder is really cool, it holds both styles of US and Japanese power bits, as well, as straight 1/4" shaft.
Vessel has the 900ALWC which has the MEGADORA style grip and a locking mechanism that is very similar to the Wiha Centrofix. It holds all kinds of bits and locks up really well. The problem is they're really hard to find.
I really like the looks of this Klein.
Yes, I believe I got mine from Ali Express of all places.That's because it's discontinued, no longer sold. Interesting enough you can get it all day long from China or the Philippines.
I just use a piece of 4.5mm diameter round stock when I need a spacer for my 397. I made sure that diameter slid freely before I cut it down and dropped it in the first time.I can’t take the Anex apart yet, nor see that well into the hex, but my guess is the bits are held into the driver by a leaf spring on a single facet of the hex. It looks like bits up to 1 5/16 long will be lost in the driver forever, short of welding a retrieval tool to it or some other method. We all have drivers for short bits. If you absolutely needed to use a short bit, I tried a threaded hex spacer about 7/8 long into the driver which spaced the 1 inch bit far enough out to be removed. When it came time to remove the spacer, I screwed a bolt into the thread and removed the spacer by pulling on the bolt. A ridiculously complicated procedure. The locked position on the Anex ratcheting mechanism is very tight with basically no play. It’s a good tool.
Makes sense. Thank you. I'd love to pay more for a made-in-Japan set but I guess there are other Japanese manufacturers for that.Taiwan, almost all makita hand tools are made there or china. Heck the majority of makita powertool line is also made in china.
Factory Gear has some other options. I think their Deen COO is usually Taiwan, though. https://ec.f-gear.co.jp/category/HANDTOOL_SET/Is there a Japanese brand tool set (1/4 and 3/8 sockets, wrenches, drivers, etc.) that is well packaged? I know of the KTC sets but can't find one I like. And Tone has sets too, but nothing interesting there either.
I also recommend the Anex, I have had it for a couple of years and Love it. I do not use it with short bits.If you don't want to wait for that Klein I recommend the Anex 397-1. Excellent ratchet driver, will accept any type of bit holder as it's a friction fit. Of course you can't use small bits directly as they will get stuck, but I imagine no one is that dumb. You can't do it on a Klein either, but with that one you can take it out easy.
