Snap on 112RTSMA
hand tools nerd
Because you know it comes with the 14 mm hex to 1/4in drive adapter by chance does anyone sell a 3/8 and 1/2 in adapter that would fit in the 112RTSMA?
WWheeler
Middleofnowhere USA
EDIT: My bad. These are Astro's 11mm hex (1/4 dr size), and their 3/8 is 17mm, so no, I don't know who else uses Snap-on's 14mm.
Astro Tools 78105 5pc 1/4" Nano Drive Size Adapter Set
You might could use something like this 14mm to 3/8 dr adapter, except it employs a bell detent instead of the notches meant to hold it in an internal hex drive ratchet:
A-3-14MM Apex 14mm Socket And Ratchet Wrench Adapter, Metric
Technical Specifications
Male Square: 3/8''
Male Hex: 14mm
Overall Length: 15/16''
H
hand tools nerd
I will get that and then get the 3/8 drive as well from snap-on
KnurledNut
n/a
The Snap-on is 11mm not 14mm so the Astro will fit but won't have any retention as they don't have retaining rings.
WWheeler
Middleofnowhere USA
@KnurledNut
Good catch.
I'd looked at them both, the Snap-on 112RTMA and Astro 78105 Adapter Set listings, and saw they were the same size and should work, but then after posting saw the OP had wrote "14 mm hex to 1/4in drive adapter" which got me all confused.
I didn't notice Snap-on's retaining rings at the bottom of their sockets is different than Astro's (and other's) in the middle. Perhaps these nano socket adapters by Pontiac787 in the GJ Classifieds would remedy that?
H
hand tools nerd
@KnurledNut
Good catch.
I have the snap on one already
WWheeler
Middleofnowhere USA
I figured. I was just mentioning that since the Astro set of adapters, as KnurledNut pointed out, "won't have any retention as they don't have retaining rings" like at the bottom of the Snap-on sockets (Astro's ratchets have a retaining ring in the middle of the ratchet and notches on the sockets) I believe you could use those 'ratcheting wrench retainer clips' to give you that retention - to keep the Astro drive adapter from slipping out of your Snap-on ratchet.
H
hand tools nerd
Do you think by chance I can get the ratcheting wrench retainer clips separately? If you don't know the answer I will talk to the snap-on guy and see what he says.
KnurledNut
n/a
I think WWheeler was referring to the aftermarket wafer type that go in the square end of the socket.
If you are talking about the Snap-on retaining rings, they do sell those separately. The part number is ME7A224K for a 10 pack.
But those aren’t going to work on other brand sockets without machining a groove.
WWheeler
Middleofnowhere USA
FWIW, Pontiac787's ratchet wrench retainer clips look similar, or perhaps same, as these to me.
I knew I'd seen something like them before. I can't be sure they are the same and will work the same to fit into the square drive end of the socket (or adapter) and provide a lip to keep them from slipping out of a ratcheting wrench, or that snap on hex ratchet, like Pontiac787s are shown to do in his listing, but they sure look like they just might.
H
hand tools nerd
Okay thanks for letting me know that
