Is this type H track???
Ryan
Administrator
Texas/Hawaii
Anyone know what type of track this is?
mike93lx
Richmond, VA
Your second Pic looks like L.
I see three part numbers, an H, L and J. The L is marked with a black dot
4xdog
Santa Fe, NM
It’s 24’ high and I’m scared of heights. :/
Maybe get one of the kids or the wife to take it down?
...while you carefully steady the ladder!
(Only 10 feet here as I put some LED light cans in my new shop's H-track last week.)
R
Ryan
Administrator
Texas/Hawaii
Another stupid question…
Let’s assume this is L-track. The current heads on this track run these 50W Halogens:
I want to run something that allows me to change the bulbs with a pole, so I’m thinking about these:
Now, these heads are for line voltage... So, I am assuming that means I need 120V L-track. And, I think that is what I have? As I’m running those halogens… Right?
sparky 1971
Central Iowa
If you can find heads like that for L style you'll be good to go. It's 120 volt track. You might already know this but if you plan on attempting to change bulbs with a pole, be sure to lube the threads at the base of the lamp or the suction cup on the end of the pole might just spin when trying to unscrew the bulb; there are a few products that are all the same, Bulb-EZ is one brand:
I've also used De-Ox in the past:
4xdog
Santa Fe, NM
For new H-track cans i got these one-piece focusable, color temperature-selectable heads the other week, Ryan. Fingers crossed they’ll be good LEDs and last a long time.
There must be something equivalent for your track? Buying new cans and then buying separate bulbs didn’t make sense to me. (Although I did ditch the halogen bulbs in favor of PAR-style LEDs when I reused some older track attachments.)
