jbailey927
- Joined
- Feb 21, 2024
- Messages
- 50
Experts,
I have a single post lift manufactured back in the 50's that was raised while the floor guys were griding and then laying down epoxy floors. Unfortunalty now the lift is stuck in the up position.
Before attempting to lower after being up for an extended period I:
1. Cleaned all the dust off the cylinder
2. Lubed the cylinder with hydraulic fluid
3. Removed all contaminates from the colar ring at the cylinder base
4. Released all air and nothing happened
As you can see I brought in the tractor and lifted the front end of the tractor up to see if that would compress the cylinder, but eventually the hydraulics on the tractor bled out and the tires just touched back down to the floor.
I would appreciate any ideas and help on how to troubleshoot and or get the lift operational again, as it has worked in the past so I know it was operational before the floor was done.
Thanks, Ben
Thanks, Ben
