hand saw storage
94legaleagle
how do you store your hand saws, besides hanging them on the wall or on pegboard? I currently have mine lying flat in a drawer of my Snap On tool box, and I keep thinking they are taking up valuable space and that there has to be a better way -
so, how, and perhaps where, do you store your hand saws at? Pictures perhaps?
Thanks:thumbup:
SteveL
St. Louis, MO
I hang mine. My back saws are on the inside of cabinet doors and panel saws are on the outside ends. Trace the area inside the handle to make a plug that the saw will hang on and add a thinner piece of the same shape with a screw so it swivels and keeps the saw from falling off. This is the best picture that I have.
Gary S
Bismarck, ND
I don't take my hand saws very seriously because I seldom use them. Between uses, mine are tossed in one corner of a basement closet. I do pretty much all my cutting with my Shopsmith or my circular saw, so my hand saws probably don't get used once every 2 or 3 years.
jwillis
SW Ohio
I'm with Gary. I don't use mine all that much, so they hang on a nail over in the corner somewhere. You do need them from time to time. So keep them somewhere where you can get to them easily. Oh, nice cabinet, SteveL.
BlindViper
York, PA
I made this up the original idea was 2 just use the wooden dowels to hold the saws. But that didn't work so well so I wrapped them with some rubber tape. Sorry but I didn't feel like taking down the ladder so the pictures kinda ****. Hope this helps!
Cword
Calgary, Alberta
Fasten a rare earth magnet (rescued from dead hard drives) to the handle and stick 'em to the side of the tool box or beer fridge.
m.james
We have a winner for an awesome Idea. You could sell them idea just saying.
1320stang
Edmond, OK
The two wooden dowels wrapped with rubber tape and pins on the wall that allow them to turn, yet are offset drilled would work as well. Maybe hockey pucks on pins?
srmofo
SW ohio
could use rubber bands too. great idea though
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
I store mine on two nails, sharp side up, between the floor joists above my basement bench. Nothing can touch the blades. They only get used every few years. For wood I have a bandsaw, 2-jigsaws, 3-circular saws, 3-table saws, power compound miter-saw, multiple hacksaws for quick jobs, and a cordless sawzall. I may rig up a panel saw one of these days... :)
maddawg308
Front Royal, VA
Saw this way to hang up a lot of hand saws from the rafters, got it somewhere on the net a while back. Would work for a smaller amount of saws, just have to make the rack shorter.
Shoottx
Plano Tx
SteveL was on the right track with the link to Woodnet, here are a couple of other options from there
Lippyp
Shropshire, UK
I regularly use a handsaw, my chopsaw and circular saw are stored in a cupboard and for odd cuts its a damn sight easier just pulling out a handsaw than it is setting up for a power saw.
rlitman
Long Island
First, let me say that your idea is awesome. I may copy it.
Second, if you need more grip, you could make the angle a little more vertical.
You could also add a strip in the front to retain the roller.
But what I really needed to ask, is:
How often you cut through that extension cord?
BlindViper
York, PA
it was speaker wire that fell...smaller dowels like 1/2 would work with no grip tape. I didnt have any at the time.
Mastermind
Ypsilanti, MI
man, you hand saw lovers would hate me :D...
my mom used to paint on them, since i was born, so imagine 25+ yrs worth of collecting hand saws, ice saws, crosscuts,one-mans etc.
i scrapped a pickup bed full of hand saws like a year ago, junk ones, plastic handles, missing handles etc.
and i don't even own a decent one. wish i could find one more atkins to keep.
ever try to use a crosscut for real? got one once that still had wax on the teeth, had to try it out. not fun.
jon12345
Yes, I keep a few lying around for just that reason. Aside from their convenience, I enjoy learning the ancient art of using them effectively and to slow the pace to get a sense for what I am actually doing. They tend to be more forgiving of mistakes, too. Tried all types of storage means and came up with a carry case I built for portable access. The pegboard plan works well in the garage, but heavy duty double pegs work the best, since I have had them slide off the single peg...that's a sound to remember. Hand saws are underrated, but probably for good reason. First off, one needs to find an old handsaw that has not been abused too much. Then, get it jointed , set and sharpened by a pro. I bought a "new" handsaw and it felt dumb, yes, no feed back from the blade. I had to say the cuts were impossible to get straight, too. The rubber grip on the handle made subtle shifts in position difficult, too. Back to old handsaws! I use a Disston D-95 (10 pt. x-cut) for clean, square cuts on large stock. Disston D-8 chisel tooth with finger hole for rips. The D-23 (10pt.) is for general use. Disston cabinet saw, D-12 (really old) for light work like mouldings and face frames. Keep a D-23 (5&1/2pt.) chisel tooth for smallish rip cuts. I keep an "unknown" brand 8pt. in my truck for use trimming lumber to fit in the truck bed. It never has been sharpened, has cut through wire nails (by mistake!) and lots of grunt work and it cuts 4x4's like butter. Wow, is all I can say. I think Atkins saws are fine examples of how to make a handsaw a professional tool, although I use Disston, mostly. If speed and production work is required; forget handsaws, but I like the minimal approach and there is much to gain by learning the required skill to use them. Compared to my Skil worm drive, they are quiet. I have learned about reading grains of wood, too, and notching is easy because the blade can cut blind flush to the stock, a nice feature. They are so light, too. If you find one at a GS or flea market, check for straightness as most old saws have been crimped from jamming the saw while pushing. They will be frustrating or at the best hard to use to full benefit. Stay away from pocked blades from rust corrosion. Fancy wood handles are a plus as those saws were usually the higher end in the food chain. That's a tall order, but if you find one that meets those standards, the rest is easy. I think the best storage solution for the saws' benefit is a closed cabinet, like the one posted above. I think that's my next project drawing my inspiration from those.
Great ideas. Thanks.
  • Disston flooring:cabinet saw.jpg
crazytrain
Amish Country, Pa
I have 2 they just hang on a nail on the shed wall. I use them from time to time when I only have to make 1 or 2 small cuts and don't feel like pulling out the power saws and cords. With my Radial Arm Saw set up in the shed they get used less and less since I just have to flip a switch to use that.
