Greenlee Knockout
qmt2
Hi Hopefully this is the correct place to post this. I need to make a 2 inch hole in stainless steel. What size of Greenlee knockout do I need? I have a set that goes up to 1 1/4 conduit size which I belive is actual 1 1/2 ......
Q
qmt2
Thanks I figured there was one online but could not find one last night.
mrb
how thick is the stainless? you may also consider a TCT hole cutter, slow speed, and the appropriate lube. Alot cheaper than a 2" punch
ecotec
a 2" punch will not be 2". they are sized by the conduit connectors they are for.
i would use an arbor and hole saw.
tcianci
Walpole, Ma
While there are punches for 2" conduit, you can also buy a 2" Greenlee punch. Lots of folks are familiar with those punches because they are used in electrical work but there are about a zillion different sizes of Greenlees.
Stuey
28m above sea level
I believe they have some sizes for conduits and others that are straight-up sizes. I'm sure there's a guide online somewhere. I'll see if I can dig it up for you.
Here:
http://www.greenlee.com/cat_docs/Holemaking_07.pdf
Component Part #s: 04611 04609 29452
or 35181 (set), slightly different configuration, I think, but still 2".
A 2" conduit punch is sized for conduit. A 2" punch is sized for 2". Refer to the link in my post.
tfi racing
Cedar,BC
Just happen to have my set next to the computer.The 1.5 inch electrical die measures 1.975",hopefully that will do the job for you,the next one up 2" measures 2.455".
ecotec
that was worth downloading. i have never seen a ton of that stuff. only the electrical punches. on the job, we use the set with the hydraulic pump. i have my own manual punches for 1/2", 3/4", 1", 1 1/4" (they are almost as old as i am. it is in a conical leather roll.).
Stuey
28m above sea level
A while back I thought the same but then looked up their catalog. The exact size punches cost a little more than similar conduit sizes due to lower demand and are a little harder to find.
Here it is at McMaster: http://www.mcmaster.com/#34685A39
ecotec
that seems pretty cost prohibitive for one hole. but it is a chance to buy a new toy.
