The VINTAGE toolboxes of Garage Journal!
I've got a bunch of six inch long pieces of 1x1 aluminum that were off-cuts from a job thirty years ago. They make nice spacers to clear the handles when stacking boxes.
Exactly the same principle. I used wood as its plentiful as short cutoff/leftovers, and IMO less likely to scratch/mark than a metal piece.
930dreamer
Amarillo,TX and Stinnett,TX
Some help iding this one, I see a socket holder on the top right edge.
Oregon rock crusher
West of Salem
That box looks like an early Cornwell to me 930dreamer. They had that exposed hinge drawer cover like that as well as the Press Steel like top rim. I have one like that but with single center drawer pulls that may be a bit later. Ed.
I found this E-Z-TOTER at the flea market this morning.
I couldn't resist the look or the name. Cleaned up pretty well, except for the alien symbols somebody unfortunately applied with a brush and green paint on each end. The convex design of the compartment keeps most of the bottom off the ground - which I assuming was the point, but I don't think they foresaw it also collecting moisture in the gutters inside, which attracted some rust that needs more serious addressing.
I couldn't find much on the company (Laube Steel, Chicago, Ill.) or its Metal Fabricating Division other than court hearings.
See attachments for more.
Mintgrun
Kingston, Wa.
I really like the rolled lip on top and the arch on the round cornered bottom. That green paint might loosen up with a soaking of simple green. You could stand it on end and the soap would pool nicely in that indentation. Sometimes, I lay a little scrap of rag where I pour the puddle. Usually, the added paint lifts before the factory paint is affected. YMMV. (I'm sure you're well aware of that process, but that's what I'd try).
I picked up a similar no-name tote recently. It'd been dropped in the Habitat scrap bin, due to dusty rust inside and some dents, I suppose. I used it as my shopping tote, while rescuing other tools and stuff from the bin. It's very light gauge steel, but still intact. It was full to the top with hammer handles, before I dumped them out for photos. It's plenty sturdy for stuff like that.
JustVicingIt
awesome graphics there
I'm sure you're well aware of that process...
Yeah,...
You might even try Simple Green first. Just keep wetting the corner of a rag with it. SG will definitely remove new spraybomb paint that is submerged in it...
I would try to remove the paint. I would start with Simple Green and cotton balls. Rub very lightly but over and over again...
But always keep the good ideas comin'!
The rag trick is also a good one. I will even soak rags in SG (as well as ER) and wrap them around parts that are too big or awkward to dip and then I use a syringe to keep them moist with it. I have a couple very long narrow rag strips I made out of an old tee shirt that I wrap like electrical tape around handles.
They could be cousins! Different shape indentations, flat bottom, otherwise very similar design.
  • Like
Reactions: 555
Founded 1948, moved HQ to West Coast in 1961. Founded by Walter Isling.
Thanks. I probably should've been more specific to save you some time from also running a search. The 'E-Z Toter' (or any other products) not showing up in the typical trade mags or business directories is what I was referring to. I plan to keep looking.
Did you see the June 1960 Popular Mechanics article?
Mr. Ising (no "l") was quite a character. In 1960 he bought 536 tanks in a surplus auction from the Rock Island Arsenal. Hmm. Now what would the president of a steel company want to do with 536 tanks?! :)
Full story here.
Teaser photo here...
Mintgrun
Kingston, Wa.
This Hand-E-Toter is listed for sale on FB MP in Seattle ($25).
The graphics are boring, compared to yours. I'm sharing it to show the sliding tray. The embossed end panels are a little bit different too.
Tom
^ Thanks, Tom!
If I was there, or if it was here, I'd probably buy it just for the tray, but this gives me the idea to cannibalize an orphan to fit.
Note that the mfgr's name is different, too. What does that say? Amsco? Clearly the same design. This will be interesting to research later today.
They came off very easily after soaking for just a few hours in SG...., but, in the 'you can't win' category, it left behind two alien symbols in a very clean shade of blue-green that is probably very close to the original color and therefore slightly darker than the rest of the box exposed to the environment all these years. :) I'm sure we've all experienced something similar with paint spatter or tape or whatnot. I don't like the looks of the rust, anyway, so I may try to touch this box up with a rattle can.
//// BREAK ////
For the ******** toolbox guys who may not venture too far from the Megathread, cross-linking a Walden BX-20 that I found and posted earlier today in the Walden thread.
Disston My Buddy
I'm glad you got it identified. It's strange to see the Disston name on something like that, although it was made long after H.K. Porter bought them out and moved the operations to Virginia.
Finally made some time to do some research on this look-alike.
AMSCO is American Metal Specialties Company and they were located in Hatboro, PA.
They sure had a thing for the whole -E- naming scheme! :)
I still don't know when Laube Steel Co's Metal Fabricating Division made the sea-green E-Z-TOTER, or which came first, and who copied whom, or if there was any relationship between the two, but Amsco TM'ed the Hand-E-Toter name in 1956, claiming first use in 1954.
Well heck, seems there are more names in play.
Simonsen marked EZToter. Even the same paint splotch on the EZ part. Wonder if they bought out Laube. More later if I find anything intelligent.
  • Like
Reactions: 555
Maintyre88
We have a winner! From what I can find, looks like it was offered from Fall/Winter 1948 thru Fall/Winter 1949. Doesn't appear in the 1948 Hand Tool Catalog, and price dropped each catalog (down to 13.50 in F/W 1949) before it disappeared. No drawer slides to speak of, and the locking mechanism is simply a U shaped piece that slides into cutouts on the side.
I just received this one. Might be for sale when I figure out the year and value of it. Says Williams on it.
