That looks very simular to a Mac MB900 series box I had in the early eighties.Clean and lube the slides and you'll have a great box.For $400 you can't go wrong.
George
I agree that automotive paint would be ideal but the cost would be much higher. I am painting an old metal cabinet(which will become my painting cabinet) for just $5 using Rustoleum. I bought 2 quarts on sale at the local lumber yard but I think I'll only need 1. Using spray cans would definitely be costly and probably wouldn't match well from can to can. Just thin a quart down a little bit and spray away! My cabinet was free so I didn't want to spend much on paint so this was ideal for me. I'll post some pictures of the cabinet tomorrow or Monday to show my results and you can get an idea about what you would like to do. I may have sprung for the auto paint if I was painting a vintage tool box but it wasn't worth it in my case. Also, don't forget to throw those handles on the buffer. Its all in the details!And, instead of rustoleum consider using automotive paint. A pint of primer and a pint of cheap single stage urethane should run you around $50-60. You're liable to spend that much on rustoleum aerosol cans to cover all that real estate.
I agree that automotive paint would be ideal but the cost would be much higher. I am painting an old metal cabinet(which will become my painting cabinet) for just $5 using Rustoleum. I bought 2 quarts on sale at the local lumber yard but I think I'll only need 1. Just thin it down a bit and spray away! My cabinet was free so I didn't want to spend much on paint so this was ideal for me. I'll post some pictures of the cabinet tomorrow or Monday to show my results and you can get an idea about what you would like to do. I may have sprung for the auto paint if I was painting a vintage tool box but it wasn't worth it in my case. Also, don't forget to throw those handles on the buffer. Its all in the details!
Grant
I have a great idea for you, find a mismatched automotive color you can live with and spray it on the cheap. If you are still bent on using a utility grade enamel, go to Tractor supply or Orschelin's and get one of their bright colored tractor enamels. The reason I say to buy there is that they sell a compatible hardner to their tractor paints and it is cheap. Hardner should improve the quality of your paint job considerably!
Van Sickle makes a pretty good quality, user and price friendly farm enamel. It is available in Ford Blue. Should be able to get it at Tractor Supply or other farm supply place.
Also check with a local automotive paint supplier in your area for "bad mix" paint ... the paint is perfectly fine, but someone mixed a little bit too much of one tint or too little of another.
Occasionally you can pick up a gallon of any given color for a song.
I think I feel like shooting a bottle rocket now!
I agree the Van Sickle tractor paint is great stuff. It is cheap, easy to work with and very durable (at least when you use the hardener). Here is a picture of an old box I painted International white over Ford blue with Van Sickle.
I think I feel like shooting a bottle rocket now!![]()
[/QI have used Rustoleum in a spray gun with very poor results. I have had better luck with "BPS" brand tractor paint, although it takes forever to dry.
QUOTE]
We use BPS in hot weather. On dry hot 90 Plus days when you do not want to paint it goes on nicely. The rest of the time we use other products Van Sickle is the norm. Do not have any tractor restores to show, but it is as good as anything I have used. You do have a very limited group of colors since there are not may farm equipment makers. Imagine how much cheaper most auto paint would be if there were only about 15 - 20 colors to deal with.
If you have the time and energy and the limited pallet does not fit, your other choice for cheap paint is mixed but not claimed paints at some stores. Then again you have to be able to use the premixed colors.
If you can use them they beat any other product I have used. I have used them in cans, through Preval sprayers, and through multiple types of guns without problems.
QUOTE]
I have used the BPS brand too, as you said, it & Rust-O-Leum tend to dry slow. Hence my preference for the Van Sickle brand.
I hope you're not thinking about a "silo" launch...![]()
You read my mind!![]()
