More kitchen problems today.
Last night, one of the coolers in the kitchen up and quit working. Fortunately, it was nearly empty at the time, so no food wasted.
Did you know your refrigerators and freezers are designed to self-destruct?
That coil in the tub full of corrosion is there to evaporate the condensate water from the defrosting cycle. Condensate water is pretty damned acidic, so it eats through the coil--which carries hot refrigerant. The coil was replaced a few weeks ago and is already pretty corroded. I left the drain out of the tub so it drains to the floor and the nearby floor drain. One problem solved.
Anyhow, the immediate problem was that the cooling fan for the condensing unit had stopped. It was too hot to work on last night--and the kitchen too busy--so I got on it first thing this AM. I keep several of the fan motors for these on hand, as this happens pretty often.
But this one had a rather unusual failure mode:
We had a mouse in the kitchen last week. I set some traps, but no luck. I guess it found its own trap.
Removed dead mouse and the fan works fine now.
