The Stihl MS 261 - The Best Chainsaw Stihl Currently Makes!
D.F.B
Australia
The Stihl MS 261 – The Best Chainsaw Stihl Currently Makes!
The following post was inspired by my own research when shopping for a new saw earlier this year. The more I read, the more I noticed a pattern, especially when comparing specs within the Stihl range. On dedicated chainsaw forums, whenever someone asked what brand new saw to buy, I'd say that in almost every reply, an MS 261 was mentioned.
From outset, I also need to highlight that the MS 261 is not the biggest, most powerful and fastest cutting chainsaw ever made. It’s cc count and price point kinda makes that obvious. Nor is it the best chainsaw ever made. No, what makes this saw standout within the current range is how Stihl created a machine greater than its sum of parts. And when you think about it, all truly great machines share that in common, chainsaws or otherwise.
Simplistically, Stihl makes two types of chainsaw. Knowing this is the first step in discovering why the 261 is a winner -
Clamshell – These saws use a plastic “sled” that the saw is constructed around. The clamshell name comes from the engine being a fully independent unit that is split in two pieces, the cylinder and lower crankcase cap. All homeowner and farm-grade saws use this design, from the baby MS 172 right through to the big dog MS 311 and MS 391. While there isn't necessarily anything wrong with this type of construction, but realistically, the only main benefit of a clamshell design is the lower manufacturing costs for Stihl.
Full Case - These saws sandwich the crankshaft and connecting rod assembly between a two-piece magnesium crankcase. This case also forms the bar oil tank. A separate cylinder is then bolted down onto the crankcase and the rest of the machine assembled around this unit. Once upon a time, all Stihl chainsaws used this design, but these days its reserved for the professional grade models, the MS 261 included.
There are multiple benefits of this design –
- A stronger support structure for the crankshaft. This makes the engine run smoother and helps support sustained high rpm running.
- Contrary to what you’d think, these magnesium case saws are lighter than the plastic clamshell saws. This is especially noticeable when comparing the entry level pro-grade saws to the farm-class MS 271, 291, 311 and 391, more on this shortly.
- More durable over the longer term.
- More conducive to rebuilding as you can simply replace the piston and cylinder without completely stripping the saw down.
Delving into the specs, this is where the picture becomes clearer. Once you see how it compares side-by-side with its siblings, it becomes quite obvious Stihl created a freak……………………..
(Please note those prices are AUD)
What the power and weight figures show the most though is how fat those farm-grade saws are. The likes of the 291 and 311 have the worst power to weight numbers, a result of excessive weight and lower power relative to the cc count. Then check out the power numbers, the 50cc 261 is not bettered for power until you look at the MS 311. The power to weight factor is not bettered till you spend big on a MS 400, which asks for an extra $350. The 261, she’s a freak in the best possible way.
So, lower weight with more or similar power means you can use the saw for longer without fatigue. This makes the 261 the perfect firewood saw, a situation where you are using the machine for extended periods making the same type of cuts over and over and over again. It’s lighter weight also makes it a go-to selection for tree climbers chunking down larger trunk sections.
Yes, the MS 261 costs more than all of it’s farm-class relatives. The MS 271 and MS 291 requiring an extra $650 or $450 respectively, the MS 311 and MS 391 needing $200 or $100 more. At the 271 and 291 price point, I get it, that’s a significant price premium. However, if you walked into a Stihl dealer with the intent on buying a 311 or 391, you’d be crazy to not spend the extra few hundred on the supposedly “lesser” MS 261. In any case, the extra spend delivers more power in a smaller, more comfortable package. You also get pro-grade features such as the manual decompressor valve, a clutch cover with captive bar nuts, ElastoStart pull rope for smoother starting, a quick release air filter cover, adjustable bar oil pump, and M-tronic automatic fuel delivery tuning (on MS 261 C-M, which is the only variant offered in Australia). Not to mention a longer lasting saw that can be rebuilt if needed. Oh, and it’s a German made Stihl.
As mentioned at the start, there are bigger and badder saws on the market. But the MS 261 is a freak of nature, a machine that punches well above its weight. Think of it like the Porsche Cayman. There are other sports cars on the market that are faster, even within the wider Porsche lineup. But the Caymen is arguably the sweet spot, a nimble and easy to handle machine that does its job in perfect balance, no part overwhelms another.
All things considered, the MS 261 is the best chainsaw Stihl currently makes.
Disclaimer - I'm not sponsored or connected with Stihl in any way, I just love the brand and have done for decades now.
Hohn
Diesel Central, Indiana
Thanks for that!
I have a couple Stihl products and have come to trust the quality. I don't own any of their saw though, because as a homeowner with a small suburban property, a battery Makita has sufficed for my needs.
Don't think I haven't eyed a bigger saw just because though.
IndyGarage
Indy
Sounds like a good chainsaw. If I needed a medium size saw and I was doing firewood all day long I might buy one. Looks like they are about $800 here in the states.
For me I prefer the next size smaller saw. I don't do that much big stuff, so the speed and power doesn't really matter, but the lighter weight and smaller bar is preferable.
cgrutt
I've owned a few saws never really used them hard bucking up some trees that fell down, helping friends cleanup property etc. Last two that I had were Stihls a MS362CM (IIRC) and a MS440 Magnum (IIRC). The MS362CM had a 25" 18" bar (ETA the 25" bar was on the 440) and was hands down my favorite saw. Perfect balance, not too heavy but plenty of power, always started right up and ran perfectly for as long as I needed it. Unfortunately sold both for financial reasons. Will definitely buy another in the future. Awesome saw.
Jay870
I have its predecessor, a 026 Pro. I have 20" and 16" bar setups for it, so it makes a great "jack of all trades" saw. Sure, I'd like to have something with a little more grunt for the big stuff, and something more nimble for limbing but can't justify the cost of saws to cover the edge cases when the 026 is perfect for 80% of what I do and adequate for the other 20%.
GirlnAgarage
Texas
Had the 261 for several years now due to the great reviews, gave it as a gift. It's cut a lot of oak on the property. It is finicky on its tune though, doesn't like to start right away. When it runs, its great. Sometimes just hit the easy button and use the Echo 4910. I've used this type of analogy before in these chainsaw threads - Stihl is like an exotic sportscar, the Echo is a reliable Honda.
Kscardsfan
The Little Apple
We run a 261CE at the park and it has become our go to saw for about everything short of major felling work. I will probably look at buying one for my next saw at home if I am being honest about it.
f121
UK
Are you running it on decent fuel? I ran my 261 hot and put it away wet back in the February storms, haven’t got to cleaning it up yet, but I’m certain it’d take a dozen or so pulls to get going and then run spot on, like it always does. Probably should do that before winter. Good call on the echo, I’ve only used a couple, no idea which models, but they were brilliant, felt lighter and more nimble than the equivalent sthil and just ran and ran. Very impressive things.
Jay870
Surprised... of everything I own that has a pull cord recoil starter, the 026 starts the easiest. 3-4 pulls if its cold and one if its warm. The 261 is supposed to be "better"/easier starting.
That being said... agree that the Echo stuff is awesome. I wouldn't give up my 026 but if I were to go buy a new gas saw today it would probably be an Echo X.
ericm
Southern Oregon
Since I already owned a MS362 I got a 241 instead of the 261. The shop really wanted to sell me the 261 they had in stock. Stihl priced the 241 only $20 less than the 261 so no one bought the 241s. But it's become my favorite saw. It's super light and manuverable, which is great for limbing. For felling trees and bucking larger logs I use the 362 or 440 or 460, depending on the diameter.
D
D.F.B
Australia
That's a fair call. This got me thinking, how much heavier is the MS 261 compared to its "smaller" brothers? Spreadsheet time!
The green highlights show the key points. The MS 212 is as heavy as the larger MS 261 but produces 1.7 times less power. The MS 251, which I always thought was all the chainsaw anyone would need, it weighs MORE than the MS 261 and produces 1 less bhp.
That actually surprises me, and again has me saying, the MS 261 is a freak!
D
D.F.B
Australia
To quote a certain Youtuber who works on and owns Stihl chainsaws, "she's a Stihl..........."
That's one area where Stihl are well behind the competition, the starting procedure for all its non-Mtronic saws is too complicated and often hard to gauge. In that I mean the sequence of full choke, partial choke, and run positions. The lack of a purge bulb means you need to pull the rope several times on full choke before the saw coughs, and if you happen to miss the cough, you end up flooding it out. The MS 250 and 251 are apparently very prone to this. I'm not sure why they persist with this arrangement, especially when other brands are easier to start. Even the rest of the Stihl product range is easier, especially the blowers with a semi-automatic choke. Now, the Easy2Start models have a purge bulb, but that is compensating for the lack of speed generated by spring assist.
The Mtronic saws are much easier, but the 500i is probably the easiest starting chainsaw I've come across. No multi-stage levers, no choke, no waiting for a cough. Just prime and pull, the saw will generally need one or two pulls to start and idle smoothly. Hot or cold. For what is a very high compression large capacity saw, the 500i is the easiest of the gas-powered saws I've owned or used. My nearly 40-year-old 028 Super is a beast to start and needs a lot of muscle to crank over. The little 009L is a bear as well.
PoorUB
Fargo, ND
My dad had a 026, and I inherited it. I run the .325 chisel and have been very impressed with it. The saw cuts with little effort. Luckily I don't used it much! I have cut down a few trees with it so I have gotten some use out of it..
Mr_B
Reading
I not big fan of any of the Newer stihl 2-mix engine saws, much prefer older models late 90's to early 2000's , they had longer lifespan and pretty easy long term repair potential .
For firewood I tend use a 023 with 16" bar, easy use/maintain low cost saw from era they made stuff run nice and last decades of hard work .
Most 2-mix stihl equipment runs like **** at first startup and compared to same model class older non 2-mix engines the 2-mix is less power & less longevity .
Firebrick43
West central Indiana
That has always been a "feature" of the pro saws.
Same goes for the 60 cc class saws like the 362. It has 4.6 hp and weights 12.3lbs to the same cc 311 at 4.2 hp and 13.7 lbs.
Hohn
compared the the 1980s McCulloughs that I cut my teeth on, all these saws are cake to start.
Lord help you if you let those saws get too cold from taking too long a break in the WI snow.
Mr_B
Reading
I still got my fathers old Partner 7000 plus and you got have some muscle start that thing when it been sat for a while, in the real cold you likely be too fatigued cut anything once got it running lol .
Still runs/cuts good today though, built of proper quality materials .
Men were built better back then too i guess lol .
Hohn
I'm definitely not man enough today to use either of the saws my Granddad and uncle had back then. I can't smell bar oil and sawdust without being transported back 45 years to the WI woods off Old Lake road near Shawano.
GirlnAgarage
Texas
Yes, always new, premium fuel. I don't cheap out on fuel with all the machines I have on the property. Not much a fan of small machine carb maintenance, but it does come up and I take care of it. Also I do not use premix. We've felled about 45 trees in the last 3 yrs on this property so chainsaws of all sizes get used with regularity. Chainsaws here are not used lightly.
GirlnAgarage
Texas
Oh gosh, yes. I do think the starting procedure for the 261 is overly complicated. It's a chainsaw, darn it. I ought to be able to pull the string twice on choke, get a cough, switch to run, pull and get a start. Or even pull twice, maybe three on choke, get a start, idle a few seconds until I can drop to run and I'm off to the races. We've discovered that if you miss the opportunity of the first cough on this 261, you're pulling until your arm falls off with no-starts, flood and you gotta let it sit. Its the most frustrating part of an otherwise great performing saw.
I'll be tuning it soon, in the next month or so for this new place. Got a lot of downed trees to clean up. I'll see what I can do to get it starting easier. Like I said when she runs, she runs. The high rpm are great but golly is it is fight before that.
f121
UK
Is your 261 running m-tronic? Mine is just from cold put it on choke, pull until it goes, blip the trigger to take it off choke then let it idle for a minute to calibrate itself. From hot, just pull until it goes.
Dakotadadv8
The 261 is a nice saw but was no big enough for 48 inch round down tree. The 362 with a 25 inch bar took care of it. If starting over the 261 and 462 or 500i would be a good combo. I do enjoy using the 362, great saw.
D
D.F.B
Australia
I bought my first "proper" saw a few years ago, the MS 271. Then two months later I was gifted a 028 Super, which needed work to bring back into service. So, I ended up with two 50cc saws. The 028 has sentimental value, so I decided to keep it and sell the MS 271, which I wasn't totally happy with. That made way for a 500i. Those two sit with a 009L and MSA 140C.
D
D.F.B
Australia
A recent study claims young men today have the testosterone levels of a 70-year-old from the 70's. So yep, men are built different now.
"Today’s 20-year-old men have testosterone levels similar to 70-year-olds from the 1970s and no one’s talking about it.
Studies have revealed a steep and consistent decline in testosterone levels across generations. In fact, the average 20-year-old man today has testosterone levels comparable to what a 70-year-old man had just five decades ago. This drop isn’t just a minor dip it’s a generational shift with major implications for energy, mood, fertility, muscle mass, and overall health."
bassJAM
Cincinnati, OH
I won't ague that Stihl makes a good saw. But I like using the best! :rocker:
Here's my Husky on the day I bought it back in 2013 and then earlier this year. Honestly I almost went with the 261, but at the time the 550xp was a little lighter and more nimble (not to mention about $200 cheaper). Same power on paper but the Husky is faster and higher revving for slicing through small limbs in an instant while the 261 is more torquey for bucking logs. Given that I planned to pair this with a larger saw for bucking I went with the 550xp. Unfortunately when they redesigned it to the 550xp MK II they made it chunky so I don't know what I'd get if I was looking for a 50cc saw today, I'd probably lean towards the Stihl.
Kscardsfan
The Little Apple
I always felt like that saw punched above its weight class running it.
cashishift
Omaha, NE
I have a 362 Mtronic - great saw. At full rip with a fresh chain its absurd how fast it moves
Also have a 025, which is my dads but he never uses it so it lives at my place now and a MS180 that I got at a garage sale cheap, she is a lil ripper.
D
D.F.B
Australia
FI Master race checking in. ;)
Can't argue with that, the 500i is a stunning machine! It's certainly a leader within the Stihl lineup, and its competitors, which is why I bought one.
The reason why the title of the thread features the MS261 instead of the 500i is as follows...............
The 500i is the most advanced saw on the market, well, at least until Husqvarna releases their new injected competitor. It's got the power, the insane throttle response, stupid easy to start, amazingly well balanced. I also love how it sounds and the way it adjusts the fueling on the fly. But........................for the price, for the amount of technology Stihl included, well it would want to be brilliant. While not always the case, but in this instance, you get what you pay for.
At first glance, the MS 261 doesn't appear to be all that special. It's relatively compact size, the "small" 50cc engine, and the fact it's the cheapest pro-level model (bar the top handles), you'd be forgiven for thinking it's an underpowered paperweight. And yet, the MS 261 has capabilities far greater than the specs and appearances would suggest. And hence the title of the thread.
No write or wrong between both.
burlapmo74
I bought a ms261 non m tonic for $20 off of a good ball where I live. I bought a performance muffler and had it ported. Still have less than a new one cost in it. By far the best saw I have ever been around. I have been around lot of saws and brands but this little saw is simply fierce. Running a 20” still 325. I am so dumbfounded by this saw. I realize it is ported and different muffler. Has to be beat thing I have ever stumbled on to
D
D.F.B
Australia
Exactly what I was getting at in the opening post. It's one of those "greater than the sum of its parts" machine. I can only imagine what porting and a muffler mod would do to it, no doubt embarrass some of the bigger saws.
jblnut
In the Middle of MN
I have an 026 with a solid woods porting job and it hangs with the kids a few grades ahead and then some. It absolutely rips. I’d love a new 261 but this 026 just keeps on chugging away.
F-22
I have the MS361. It's like the other side of the coin - both can do everything, but while the 261 is more firewood-oriented with some good capability for cutting down trees, the 361 is more felling-oriented but still light enough to cut with it into firewood.
The advantage is I think a wider and more robust chain (unless I am mistaken, didn't check). Such a chain is also a bit easier for me to sharpen. And the more heavy and powerful saw will also chew through wood even if it isn't sharpened optimally. I know those lightweight ones struggle a lot in such cases and you really need to be accurate with your sharpening...
Provincial
Near Salem, OR
I bought an 026 Pro about 35 years ago, and loved it. I use a 20" bar on it and 3/8" chisel chain on all my saws. I used the 026 to fall, limb, and buck Douglas Fir trees up to 16" diameter in a thinning operation. It was great until it was stolen, and I replaced it with a MS260, also with a 20" bar.
The MS260 is just about the same in power, weight, and performance. It may well outlast me, as I am getting up in age.
I use my 044 for bigger trees. Mostly a 24" bar, but also a 30" bar for really big stuff. I cut up a large Oak for firewood that was over 36" in diameter at the lower end, so I had to come from both sides with the long bar. The 044 will for sure outlast me.
I use the MS260 for limbing even when I am using the big saw.
Treeman
Our MS260's have been our go-to saws at my workplace for decades. It fits our needs best, and our 362 handles most things bigger. I must be doing something wrong, but starting has seldom been an issue that so many make of it here. Regarding the testosterone discussion above, saws are similar to pick up truck (bro truck) discussions. Those who are serious with their saws match the saw to the work.
GCS
Oklahoma
Enjoyed reading your comparisons…
I have a 025 that’s 30 years old thats my go to saw.
A few years ago I was needing a bigger saw than the 025.
I had it narrowed down to the 261 & MS311.
Your points are spot on. I was on the fence going back and forth between the two, but ended up with the 311.
Price point and usage were the determining factors. Mainly useage. Which goes right back to price…
So far no complaints on the MS311, but no doubt the 261 is a great saw
