Thanks.Are you referring to the DC current for the weld or the AC current draw from the wall?
In either case, it appears that welder can operate across a range of power outputs with varying voltages/currents. It looks like the AC current draw from the wall at 110 volts can range between 12 and 22 amps depending on the weld settings.
I is current
U is voltage
