Which Amperage
Levaughn
NY
This vintage Bokrank Gmbh "Golden Gate" welder shows different amperage's. What is the true amperage for this welder? Thanks.
GeoBruin
Are you referring to the DC current for the weld or the AC current draw from the wall?
In either case, it appears that welder can operate across a range of power outputs with varying voltages/currents. It looks like the AC current draw from the wall at 110 volts can range between 12 and 22 amps depending on the weld settings.
L
Levaughn
NY
Thanks.
