water leaking thru gap just outside overhead door
zekenator
Andover, MN in 3 weeks!
We semi-recently had my entire shop re-skinned. It looks amazing now. (pics and story later)
For the purposes of this post though, I have seen water leaking from the side of the overhead door even with a new door seal and everything. Finally had the time to really look into it and found the problem. How would you fix this? I need to do this ASAP, like before winter. This coming weekend will have great temps here in Minneapolis so I want to do it then. I was thinking Loctite PL Window Door and Siding sealant but the gap may be just a bit too big. Thoughts? Thanks all
See pics and comments
You can see below where the post is getting moldy from several years of water damage due to the previous owners being too busy making meth and selling guns to take care of anything at all. Thinking I'm gonna make a water/bleach solution and douse it all bigtime. Then after that dries do whatever fix I decide on.
BillK
Beautiful Southern Maryland
We semi-recently had my entire shop re-skinned. It looks amazing now. ..............
Except for the part that is leaking ????
I would get whoever reskinned the building and tell them to do it correctly ? If you want to fix it you probably need to bend a piece of flashing to go up behind the siding first. Then seal it up. Probably should pull the door seal off also. Are both sides of the door the same way ?
shade
(Formerly)Phoenix, AZ: (Current) SW MI
Second the flashing.
Pull the sheet off. Replace the wood
Flash
Sealant
BillK
You might want to post a picture from the side too. I might be wrong but something does not look right about this spot where I have red arrows pointing ?
PCustoms
VT
Looks like the closure/edge(I forgot the actual name) for the bottom of his metal siding
BillK
Might be but it looks like it would hold water to me. Should look like this :
PCustoms
VT
Agreed.
I had just die some trim around a door and struggled to get the right material, so I was thinking about the wrong profile
charbar
Midwest
Is that friggin J-channel????!? Hard for me to tell for sure......
