I have this “knock down” bench for large projects. (it also has a 3/4” top not shown here)
Is that a purchased bench or are there build instructions somewhere? That looks interesting.
Either WoodSmith or shop notes magazine about 12 or so years ago.Is that a purchased bench or are there build instructions somewhere? That looks interesting.
We subscribed to the same magazines.Either WoodSmith or shop notes magazine
It's WoodSmith Issue 229. That has the plan for the knockdown bench.
Jeez, that's boring. The real fun is waiting for three feet of snow and a 40 knot blizzard to do the work.Instead of my usual procrastinating until the weatherman says it's gonna snow and snow a lot, I pulled the ATV in and changed the oil, greased it, pulled all four rear tires off and put the chains on, put the snow plow bracket and lift mechanism on, and pulled the blade out so it's ready to go. Hopefully I won't need it for a couple of months, but I'm actually ready ahead of time for once. Then, I decided there's no more lawnmowing going to happen this year so I put the fuel stabilizer in the tanks, drove them around to get it mixed and into the carbs, and tarped them up behind the garage. I'll see them again in April. I hide from the phone when I'm not working so I didn't have it while in the garage. Photos are obviously taken after I was finished.
Been there, done that for the last 10 years. Two, maybe three, years ago, even with the axle locked and five sandbags in the bed, I couldn't get enough traction to get up the hill and into the garage until I got the chains on the two rearmost wheels. The front rear tires have to come off to get the chains on and it's faster to pull the rear rear tires. No more.Jeez, that's boring. The real fun is waiting for three feet of snow and a 40 knot blizzard to do the work.
I surprised myself by changing to my winter tires last year before I had to do it in the snow.Been there, done that for the last 10 years. Two, maybe three, years ago, even with the axle locked and five sandbags in the bed, I couldn't get enough traction to get up the hill and into the garage until I got the chains on the two rearmost wheels. The front rear tires have to come off to get the chains on. No more.
I try to religiously put the snow tires on my service truck and the tire chains on the passenger side floorboard by the second weekend of November I hope we don't get one of the rare early November blizzards since I talked myself out of it today. Everything else in the fleet is a 4X4 with all terrain tires year round.I surprised myself by changing to my winter tires last year before I had to do it in the snow.
Probably a one-off.
Weather is calling for heavy snow above 4,000' tonight. I live at 3,750, so probably heavy slush. Did I get the tires changed?I try to religiously put the snow tires on my service truck and the tire chains on the passenger side floorboard by the second weekend of November I hope we don't get one of the rare early November blizzards since I talked myself out of it today. Everything else in the fleet is a 4X4 with all terrain tires year round.
Look into a Gray-Hoverman antenna. They're very directional, but **** in the signals, even from multiple reflections and refractions. I built 3, with reflector grids. They're in my attic. There's tons of plans, including some made from old exterior antenna elements.Youtube tv lost espn. So to make it easier for me to drop youtube tv, I need to get local channels working ota again. I mounted the small antenna I have in a window. It kinda works, but I'm thinking I'm going to get a larger outdoor antenna to mount on the roof of the shop. The metal building is screwing with the signal, plus we're a bit far for the antenna to be so low.
Hell, I can't pronounce it!What are you using for a player these days?
Actually, it's back to Standard time tomorrow. Sleep in an extra hour (yeah, right), wake with the sun up and it gets dark an hour earlier.I'm guessing no... still an hour or so of daylight!
and DLST tomorrow!
The dogs like to urinate on our rolling gate, so it causes a lot of rust issues.
I agree a small section of electric fence would be an ideal solution.Tell me you doubled the gaug eof the metal used!
Also you can *** a little section of electric fence wire, and eliminate the problem! They may do it again, but only once!
Oh, boy! I get to reset every clock in the facility!
Enough already. Just stop it. Knock it off. You can't change time (time can change you).
If you want to get up an hour earlier in the summer, talk to your boss. Don't ram it down my throat.
PS: When Ben Franklin so famously proposed something like Daylight Savings Time, he was writing satire.
Get off my lawn!
