jblnut
1/3 of a cord by volume.isnt a face cord just half a cord??
seems like an odd way to measure. "i just put 12, 1/3 gallons of gas in my mower."1/3 of a cord by volume.
Maybe you already know this but thought I would throw it out there.
I was doing some research on a ih 574 today and ran across a thread that made me think of your issue with your old tractor. Alot of people were saying they were hard starting under 50° and needed plugged in or ether to start. One of the posters said he never had a issue even in the winter by using the cold start position on the kill cable. He said to pull the kill cable out half way and this was the cold start position.
I saw your compression check and agree it probably needs a head gasket but didn't know if you knew about the cold start procedure.
I use a friend's 2025 at the lake now and then. He doesn't have the tires loaded or any weights on it. I've had it on two or three wheels more times than I can count. I was pulling water logged dock floats out of the lake last month. Could get them part way up on shore with the loader then had to turn around and pull them the rest of the way out. If I end up with one I will definitely weight it and shim the pump. They are pretty handy.
seems like an odd way to measure. "i just put 12, 1/3 gallons of gas in my mower."![]()
Nice update. Nice garden produce. Summers like this one in the garden always remind me I am grateful I don't make my living from seeds I put in the ground.
Our garden yield wasn't very good this year. The weather was a yo-yo between extremes. You may have done better than us in just that picture! I recall you're a ginger so it looks like your daughters are as well!
Looks like you had a fun summer.
You’re a busy guy. Yikes first snow storm scheduled already that’s crazy.
Nice looking tractor. Good luck with winter
You, Strouty, me, and the rest of us northerns are rushing to get prepped for the white stuff. Good luck getting ready.
I have that same snowblower but in red. Really like it. Make sure you have spare shear bolts on hand. I just use regular (NOT grade 5 or grade 8) bolts. Much less expensive and work fine.Thanks! This stuff likely won't stick around as it's pretty warm during the day yet, but I could be wrong. I was last year.
You too Kirk. Hopefully you have more time to prepare than I do. They are calling for lake effect snow here from Sunday through Tuesday. I really hope it's not like last year; that first lake effect storm was a really miserable sucker as the lakes were still really warm to fuel it. That's the one that dropped 18" on me, and 3' on others about 10 minutes from here. I really hope we don't see that again as I've heard that a lot of people have had their snow load coverage dropped by their insurance after that storm.
I picked up the new blower and got it hooked up, now I just need to get the PTO shaft installed and it will be good to go.
I have just read most of your posts and enjoy all you have done from start to now
thank you and please keep posting + photos
Graham
I just got caught up on your thread and wanted to say congrats on the tractor! I'm sure its going to be a fantastic help to you around the property.
These newer John deere compact tractors are really fantastic.
Chainsaw is an easy fix. Drain as much as you can. Fresh oil and gas mix. A few extra pulls and some extra smoke, and you’ll be good to go.I don't think I'm very different than most of you guys here on GJ in that I like to get new tools. But this is the second time that they are coming from a family member who will no longer be able to use them, and I'd really like for that to stop.
This has been in the works for a while, and I'm glad to finally have everything here. All of these tools, plus a lot of hand tools and hardware, came from my grandfather's place. His health has been deteriorating recently and he was finally admitted to a long term care home this year, so his estate is being cleaned out. They had all of the grandkids come through and take or speak for anything we'd like. There was a few things I really wanted that I didn't get, but I'm glad to have got what I did. Some of these tools will fill a really big hole in my woodworking equipment lineup.
Most of the woodworking tools were bought by my grandfather in 2008/2009 but were hardly used. Some, like this forstner bit set, hadn't been used and where still in their original packaging.
The new tractor again came in handy. This turned a difficult two person job into an easy single person job.
Now the hard part, figuring out where to put them in the shop. I really need to get a dedicated workspace setup for woodworking, but that area is currently occupied by the Avalanche.
I also need to do some fixing. This is a MS170 chainsaw that I also got from the estate. You can't tell in the picture, but it looks like in one of my grandfather's less lucid moments he put bar oil in the gas tank, and gas in the bar oil tank, and tried to run it. Hopefully that's not a difficult repair.
Oh, and it snowed yesterday.
Yes it's sad on how some items get acquired but...as long as they know you will take care of them it's much better than getting tossed or given away just to clear out. I have a lot of my uncles work tools and confident he would be glad they're being used to help out at mom's house.I don't think I'm very different than most of you guys here on GJ in that I like to get new tools. But this is the second time that they are coming from a family member who will no longer be able to use them, and I'd really like for that to stop.
I'm sorry to hear how you acquired the tools, but those certainly get you up and running on the woodworking side. Just need a table saw and a planer. Now I get your question around cutting boards in the woodworking sub-forum. I measured one I made over lunch and it's just under 3/4" thick and 10"x17". Been using it for two years without any issues.
I did the bar oil / gas tank thing on my Stihl (once). It was a pretty easy recovery.Oh really? I assumed a carb cleaning and purging the lines was in my future. That's good to hear.
I will agree with you about acquiring tools like that, but it is a nice way to keep the memories alive. Some of the tools in my shop will forever be Uncle Bob's lathe, Uncle Marvin's level, Dad's ladder, etc.
Every time I pick up the Snap-On ratchet, I think of Grandpa Lambert. Ok, now I'm feeling very melancholy.
We got some of the dreaded white stuff here yesterday and last night as well.
What's the verdict?Plus it gave me a chance to try out the new snow removal setup.
What's the verdict?
I hear you about the tools from family members I have quite a few in my shop for my grandfather. I'm quite confident he'd be very happy to see me still using some of his tools.
Those type of tools from family members that passed or can’t use them are sometimes nice but depressing. But at least they are going to be used again.
Keep the white stuff in your backyard, they calling for some mix frozen stuff tomorrow.
SOP now a days. What are you going to do with the wood?It's funny, we had that first dump of snow and then it all melted after a few days. Now we have another few inches on the ground, but it's supposed to melt too. We seem to be in a roller-coaster pattern of heavy snowsqualls and then warm weather.
I'm not looking forward to when it gets colder and the lake effect gets really fired up.
