Beerhippie
Far NE Oregon
Beerhippie - this would have been useful to you for your new camera equipment case: Home Despot
I picked it up a few weeks ago when they had a promo that included an additional battery. It was $99, so I'd bet they come up with a black friday deal soon that's similar.
That would be handy--the one time a decade I need to cut foam. I was wondering if I could use some tungsten wire and my old Weller soldering gun to make a foam cutter. Seems like it would work... what could possibly go wrong?
A buddy gave me a BIG piece of the dense black pick-a-cube foam. I may replace some of mine with that.
Back to topic:
Been fighting the CEL codes on the 95 T-bird for several days off and on - D0102 (MAF) and D0155 (Bank 2, (O2) sensor 1)
102: changed the Air filter, cleaned the MAF screen 2X cleaned the connectors to it 2X...
155: Looked like the heater on the DS front O2 sensor was dead so I bought a new one and; Nada. its not happy still...
Fixed one very obvious vacuum leak. (Rotted elbows...)
Codes won't stay away...
Beginning to get irritated with this!
Just did detailed voltage and resistance tests on the MAF "its dead Jim" On order. for delivery later this week...
rktinc
Midwest/USA
We had a similar situation at work many years ago. Actually worse as it was in the doorway between two buildings and there was an inch of elevation change. Heavy forklift traffic all day long with 2-5,000 # steel coils moving one way and fully laden scrap hoppers going the other way. All day long, banging and bouncing.
I ended up cleaning out the area on a Friday afternoon and using Devcon epoxy floor patch. After cleaning mechanically and blowing it out with compressed air, I used lacquer thinner and a wire brush to make sure that any residual oil was removed. It worked perfectly. the patch held on until the building was sold 15 years later.
The Devcon stuff wasn’t cheap, but was absolutely worth it. The area was well ventilated, but I probably should have used better PPE, but I lived to tell about it.
I appreciate the advice. I am adding that to my YouTube research list:)
rcktpwrd
Raleigh, NC
Repaired a string of Halloween lights, found two bad bulbs:
One of the contact wires broke off, I replace a lot of bulbs like this in the box store light strings
Shower curtain hooks weren't rolling smoothly
so I soaked them with some penetrating fluid and gave them a scrub with a tooth brush, better but they are just worn out
nadogail
Coronado, CA
I saw a large heavy plywood work table with shelves and casters in the alley a block and a half from my house, i pushed it home with my mobility scooter.
The top looks to be furniture grade 5/8" plywood, the side panels look like 1/2" and the back panel is quarter inch, the shelves that were loose in the bottom look like 12" wide clear stock.
I don't need the table, but the material it was made from will certainly become parts of future projects.
Sometimes even a blind dog finds a bone.
SMOKEYBEAR
Went 2-1 yesterday with the dually brakes
Parking brakes are on - W
Rotors/ hubs are on - W
Adjusting the parking brake - L
I have the passenger side adjusted like I want it, the driver side gave me the L. The adjuster spoons I have work well to adjust them one way, if I have to turn them up no problem (passenger side)...turn them down, not so much (driver side) I heated, bent and ground 1 and still have poor results. Evidently I need a Lisle 51300, going to try and find one in town after I vote today.
Jay870
I'm going to assume the DRW adjustment wheel is accessed through the same tiny, poorly located, and awkward to access slot as the SRW. Yeah, I'm buying the tool before next time too.
SMOKEYBEAR
Thats the one. It's actually worse on the dually. My Excursion and SRW F350 were no issues with the tools I currently own.
niget2002
Josephine, TX
This was late last night...
My son had a tennis match a few towns over. He started getting a headache during the match. When he was done playing we left and grabbed dinner before heading home.
He was acting weird on the ride home, so I kept checking on him and he just said, "my head hurts".
3 blocks from the house he throws up without warning.
So, what did I do in my garage last night? I spent a lot of time cleaning the front seat of my truck with a carpet cleaner.
I haven't been out yet this morning to check on smells. I left the windows cracked last night hoping it'd help air it out.
niget2002
Josephine, TX
Concussion? You have a likely cause, and multiple symptoms.
Possibly a slight one. We're monitoring him. My wife works at the school he goes to and can keep an eye on him. He was his normal self this morning and said the headache was gone.
We weren't that concerned last night because of the following:
He's about the age where I started getting random migraines once or twice a year. Mine were typically stress induced and he has a LOT going on the next few weeks. Mine would get bad enough it'd cause me to lose my lunch. He was acting almost exactly like I remembered feeling when they'd hit me. So last night, my thinking was he's unlucky enough to get my migraines and we'd have to be dealing with that the next few years. He didn't bring up the racket until he was putting his shoes on this morning.
Apparently, the racket incident happened during practice earlier in the day and he just 'had a headache' from it. He played the entire tennis match with the headache and didn't even mention it until we were on our way to dinner.
Snip's
Today, in the garage I decided to do some preventative maintenance to my 2016 P-car...
In their infinite wisdom, they used a spinning disc hard drive to operate the PCM...
The hard drive have a known history of failing at some point...
Of course their solution is to replace the entire PCM @ several thousand dollars, once it crashes...
The DIY solution is to copy all of the data from a good hard disc over to a SSD...
I used a StarTech duplicaticator deck to make the transfer to a salvaged Windows 10 decommissioned computer SSD I had.
Took all of 30 minutes to transfer the data onto a free salvaged SSD...
Installed into the PCM, buttoned up the dash and the P-car started right up with no issues...
Beerhippie
Far NE Oregon
Hauled out an ancient HP Pavillion laptop computer to see if it still works. It boots and runs! It took two tries to boot it up. Funny how hard it is to feel nostalgic about a BSOD.
Win XP Pro. Last file change seems to be about 2005. No idea what to do with this dinosaur.
Beerhippie
Far NE Oregon
The pressure bleeder I bought to bleed my Toyota Corolla brakes and clutch came with an adapter that doesn't fit my rig. Trying to find one that does--frustrating.
So I decided to make my own from brewery fittings. A 1 1/2" TC cap fits the ~50mm top of the reservoirs just fine, si I cut out a gasket from soft silicone to fit and cobbled together a few other fittings:
It fits, but the rim of the reservoir isn't enough to allow the clamp to clamp, so it doesn't hold pressure. Grrrr....
Here's what the top of the reservoirs look like:
The caps are just rubber boots that slip over the rim, but inside you can see two bayonet fitting that appear to be there just for a pressure bleeder--now to find the adapter that fits those.
You can see why I want to change the fluid....
Beerhippie
Far NE Oregon
Beerhippie
Far NE Oregon
Don't put it on the internet. :)
Install "Windows 11 Lite" (Tiny11, AtlasOS, Ghost Spectre)
or Linux.
I may be stupid, but I ain't dumb!
It might be a good candidate for a Linux "trainer". Guess it wouldn't be a bad idea for this old dog to learn a new trick or two.
It has a whopping 100GB of hard drive--and it's a real, spinny, HDD. I'd kind of forgotten that sound.
Beerhippie
Far NE Oregon
Here's what else I did in the shop today:
A near-total waste of time.
kaymccampbell
Upstate New York
Back to topic:
It'll keep you off the streets at night.
kaymccampbell
Upstate New York
Remote the intakes. It's amazing how noisy they are. I used old vacuum hoses to route mine into a dead space. Made a world of difference.
partsguy5768
Not much shop time lately...parents gone, grandma gone watching two of the grandkids. Grandpa's why of doing pudding vs grandma's... whip cream bartender. One bite one shot... they agree Grandpa's way much better...
pancholasvegas
About a week ago, I received the front-end back from powder for the pedal car.
Unfortunately, I wasn’t happy with the finished product. Excess powder coat, uneven application, and the it was bent out of plane in several areas.
Not gonna be able to find another one, so I thought I’d try my hand at working one up that was a bit more stout.
I started by disassembly the piece and mocking it up in the flat. Laid it out on a piece of stock.
That one’s simple enough. I also need to make the steering arms. I drilled a hole to use for clamping the piece for tracing, and also to use in the final assembly.
Roughed out.
Next, I cut them to actual size. Cleaned up with the belt file and sander. Cut out the relief for the axle. Next the axle assembly was bent up. I did leave each end long at this point, I will cut to length before finalizing.
Scribed out the slot for the steering column. Finished that section by chain drilling and a file on the inside.
Satisfied with the fitment of everything, I TIG’d the post/axle in place. Mocked up below with the original assembly. Going to test fit everything to the car and then I’ll rivet the pieces together per factory.
Test fit to the car and satisfied everything worked out. Now I’ll get it painted and be onto the seat next!
Beerhippie
Far NE Oregon
While screwing around with everything else, I was looking at the power supply for this ca. 2000 HP Pavillion giant-*** multi-media laptop:
Why don't they do that anymore? A laptop is a portable computer, and being able to charge it from the cigarette lighter port (power port to you kids) is beyond handy. Sure, you can use an inverter, which is just one more toy to buy and keep track of.
You may now return to your regularly scheduled thread. There's a cloud on my lawn I need to yell at....
kaymccampbell
Upstate New York
Roughed out.
You could powder coat those parts. I find that my half-assed rig gets me at least as good as the local butchers do. A convection oven makes a nice PC oven, and those parts are small enough. I've got a cheapie HF PC gun, Prismatic Powders colors, and an old oven that the induction head died on. You could even use the home oven, so long as you run the clean cycle afterwards. And run the range hood while it's going.
pancholasvegas
I think that’s actually going to be a reality sooner, rather than later. Christmas is around the corner and I do a lot of small stuff so it’s easily justified.
M.Brane
1 hr N/W of LA LA Land
Been watching this closely as the Tool Box Truck has good pads/rotors, but the parking brake is lacking. I suspect it got driven with it engaged, and trashed the shoes. I have a good selection of adjuster spoons, and a grinder or 6. Also access to a torch if it comes to that.
One thing I used to do with my old drum brake vehicles was mark the backing plates with the adjuster orientation. It's hard to remember that sometimes after you've been struggling with the jack, stands, and creeper.
